Kubota MX5100 or Mahindra 5530
   / Kubota MX5100 or Mahindra 5530 #11
Congrats! I don't think you will be sorry. I wasn't.
Trying to post a picture from my phone, but having a hard time....I hope I don't have this hard of time with the tractor......
   / Kubota MX5100 or Mahindra 5530 #13
Congratulations!
Did you get a warranty on a used tractor? Hopefully you won't need it. Kubota has made some good equipment.
Thanks! Yes Sir I was able to get a full factory warranty because this tractor was leased to a local peach farmer for a couple of months to pull their wagons. To clear that up I was able to get the warranty because technically I am the first buyer.
I think there are a lot of good tractors out there these days. Some are better in different areas than others but overall they are all good especially if you are good to them! I was really looking hard at a Mahindra but ended up with a better deal on this Kubota and by all means I am not disappointed!!!
   / Kubota MX5100 or Mahindra 5530 #15
For the size and power, my MX5100 is the best tractor I have ever owned.
   / Kubota MX5100 or Mahindra 5530 #17
Good choice saving $4000. You can add a lot of attachments for that amount.
Well I finally got the pictures downloaded to our computer. The first picture is the tractor on the dealers lot with the R4s and without a loader. I had them swap out the R4s for Ag's and install the FEL, also got a 6 foot landpride cutter. I am very happy with this tractor so far, I really feel I did make the right deciscion, kinda funny when I started this tractor buying adventure I said I would not get a Kubota...I guess I ate those words.
I got to use it for a couple of hours Saturday morning before we left for vacation and I found out the slip clutch does work on the cutter. I found the the chain link gate that I knew was out there in the old pasture that has not been mowed in two years. You can kinda see how overgrown it got in some of the pictures. I had a good idea where the gate was located and I was easily backing the cutter into the spot, I didnt see it while backing in so I went to pull up to move over a bit and thats when I found the gate. I did manage to wrap the wire up in the cutter and then the slip clutch did its job and shut the cutter down. I got the wire clear from the cutter in about 20 or 30 minutes and engaged the PTO to make sure everything was still working and it was. Is there anything I should check on the slip clutch or cutter when I get home before using it again?
   / Kubota MX5100 or Mahindra 5530 #19
Thats a nice lookin set up! I have R1's on mine and i wouldnt have it any other way in my terrain. I really like that LP cutter!
2015 John Deere 135G Hydraulic Excavator (A50322)
2015 John Deere...
4K SAND SEPARATOR (A52472)
4K SAND SEPARATOR...
2016 Chevrolet Impala Limited Sedan (A51694)
2016 Chevrolet...
New Holland 155 Hay Elevator (A50774)
New Holland 155...
John Deere 915 Flex Head (A50774)
John Deere 915...
2016 Ford Explorer AWD SUV (A50324)
2016 Ford Explorer...
