CASE 1175 TRACTOR - NEED LOCATION OF HYDRAULIC OIL FILLER
   / CASE 1175 TRACTOR - NEED LOCATION OF HYDRAULIC OIL FILLER #1
BOOLIVER
MARION, MI
CASE 1175
I just purchased used CASE 1175 tractor without a manual. I'm looking for the location of where to fill it for the hydraulic hoses and type of oil that it would take and how many gallons it should use. Thank you.
   / CASE 1175 TRACTOR - NEED LOCATION OF HYDRAULIC OIL FILLER #2
Never been around a 1175 but do have the service set that includes the 1175. The book says it holds 64 quarts of "Case TDF Fluid". HyTran I believe is what they call it now. The oil fill I think will be on the left hand side looking at the rear of the tractor, close to the top link bracket if it has a 3-point hitch. Other tractors of that era have sight glasses on the left hand side just ahead of the brake and rear axle.
Kim
   / CASE 1175 TRACTOR - NEED LOCATION OF HYDRAULIC OIL FILLER #3
Kim
I have an 1175 and the oil hydraulic oil filler is on the back above the PTO output shaft.
2015 Ford F-550 Auto Crane 4004EH 4,000LB Crane Service Truck (A51692)
2015 Ford F-550...
2015 Chevrolet Express 4500 Shuttle Bus (A50323)
2015 Chevrolet...
2015 Crane Carrier Co. Low Entry (LE2/LD2/LW2/LT2/ST2/SD2) Truck (A51692)
2015 Crane Carrier...
NEW HOLLAND 706 30 INCH 3PT DIRT SCOOP (A52748)
NEW HOLLAND 706 30...
2019 Ford F-350 4x4 Crew Cab Auto Crane EHC-4 4,000lb 2 Ton Mechanics Crane Service Truck (A50323)
2019 Ford F-350...
2021 Club Car Carryall 500 Utility Cart (A51691)
2021 Club Car...
