ROPS low clearance warning
   / ROPS low clearance warning #11
That's one of the 1st things I did after getting my 3032e 2 yrs ago. I wired a piece of 1/2" pvc pipe to the grill guard and adjusted it to work as a telltale for upcoming tree branches and door ways. I even spray painted it JD green!
Steve
southiowa
   / ROPS low clearance warning #12
Get an old bell and rig it up somehow so it is suspended several feet in front of the doorway, but at the right height to hit the fully raised ROPS. The idea is for the ROPS to hit it, and ring the bell to remind you to lower the ROPS.
   / ROPS low clearance warning #13
I'd hang a pvc pipe across the inside of the door entrance. High enough to clear the folded rops, but it will probably still hit you in the head as you pull in.
   / ROPS low clearance warning #14
Hang a sign from the inside of the door (if a garage door) or from the ceiling inside the door (if a sliding/swinging door) that says "Fold down ROPS before entering"
Aaron Z
   / ROPS low clearance warning #15
Young people hang a tennis ball in the center of the door where it will hit them in the face as they are driving in to remind them. Us old folks use a basketball instead of a tennis ball.
   / ROPS low clearance warning #16
I never have to put my ROPS down, because the door to my barn is high enough. However, recently I did have to temporarily move my tractor into my garage, which has a door that is not high enough.
I was backing it in, and right when the hoe went in the door, I remembered that I had to put the ROPS down. I stopped and realized at that moment, how easy it is to forget. I credit this save, at least partly to the fact that I have read so many posts by members who forgot. :alert:
By the fourth hit, I would have to seriously consider just leaving it down.
I lieu of that, how about a sign that says: Wanna Try For #5?. :D
   / ROPS low clearance warning #17
You are not alone. I put a tool box in the middle of the door opening that forces me to get off the tractor before entering. Then, I always remember.
MoKelly
   / ROPS low clearance warning #18
I would think that some enterprising electronics engineer could design an alarm beeper and warning light (installed on your tractor) that would activate when your tractor was within about 30 feet of the door - kinda like a back-up alarm.
I think such an alarm could be sold to LOTS of tractor owners...and maybe quite a few roof-top bikers too. ;)
   / ROPS low clearance warning #19
I like this low cost, simple solution. :thumbsup: Maybe also put a reminder sign on the door?
Don't even need the reminder. Since you'll be getting off of the tractor to open the door, you'll see the ROPS as you turn around to walk back to the machine. Zero dollar investment.
Okay hung a tennis ball (don't have basketball) on the door and also will close the door after exiting. With those 2 reminders, hopefully there wont be a 5th time! Thanks to everyone for their suggestions. :thumbsup:
Galvanized Livestock Wire Gate - 4FT x 11.5FT (A55218)
Galvanized...
Oil Well Pump Jack with Motor (A52377)
Oil Well Pump Jack...
2016 Ford F-550 4x4 12FT Landscape Dump Truck (A51692)
2016 Ford F-550...
2019 JOHN DEERE 310SL HL BACKHOE (A51406)
2019 JOHN DEERE...
Bell B30E 30 Ton Articulated Dump Truck (A52377)
Bell B30E 30 Ton...
RHINO DB150 LOT NUMBER 73 (A53084)
RHINO DB150 LOT...
