Injection Cleaner for Tractors?
   / Injection Cleaner for Tractors? #11
Only thing I use is Howse in the winter.
Chris
   / Injection Cleaner for Tractors? #12
Need to read Bosch's comments on the low lubricity effect of American ULSD on their pumps, and read about problems with newer 1 ton and smaller diesels that use the Bosch pumps.
Links have been posted on this forum.
   / Injection Cleaner for Tractors? #14
I use off road diesel. I have one of the large filter funnels that takes out water and small contaminants on the way into the tractor fuel tank. Then I put in some Power Service once it is in the tractor.
I expect the funnel to detect any diesel bugs, and the Power Service to keep the fuel nice after it is in the tractor.
   / Injection Cleaner for Tractors? #15
pull a UOa before using Power S and after Power S...I will never use it again...watch your wear spike using it..using MMO or 131 is way better. But ha, you cannot but (1) at walfart.
   / Injection Cleaner for Tractors? #16
From http://rivrdog.typepad.com/files/copy-of-diesel-fuel-additive-version-3.pdf
10) Power Service Diesel Kleen + Cetane Boost
Multi-purpose
Cetane improver, bio-diesel compatible, alcohol free
HFRR 575, 61 micron improvement
400:1 ratio
8.32 oz/tank
$1.58/tank
17) Marvel Mystery Oil
Gas, Oil and Diesel fuel additive (NOT ULSD compliant, may damage 2007 and newer systems)
HFRR 678, 42 microns worse than baseline fuel.
320:1 ratio 0.4 oz/tank
$3.22/tank
   / Injection Cleaner for Tractors? #17
Power Service in the white bottle is what I use.
   / Injection Cleaner for Tractors? #18
Chris
Use either Hawes or Kleen Flo. Have gotten too many horror stories on PS gelling in the colder climates to even risk buying it. Also use it year round for lubricity.
2018 FREIGHTLINER BOOM TRUCK (A51406)
2018 FREIGHTLINER...
UNUSED IRANCH HYD EXCAVATOR THUMB CLAMP (A54757)
UNUSED IRANCH HYD...
2015 Infiniti QX60 SUV (A50324)
2015 Infiniti QX60...
2014 Ford F-150 Ext. Cab 4x4 Pickup Truck (A53422)
2014 Ford F-150...
CATERPILLAR 615C MOTOR SCRAPER (A51406)
CATERPILLAR 615C...
2020 CHEVROLET Z71 TEXAS EDITION TRUCK (A51406)
2020 CHEVROLET Z71...
