Hydraulic pressure from divert low? F22
   / Hydraulic pressure from divert low? F22 #1
guyd
Hi
my F22 has a hydraulic divert lever under the seat, which switches on a pair of ports, which I have used for the FEL. All works as you would expect, except the lift capacity is poor. is this divert thing limited - or is the main hydraulics suspect? I compare it to my last tractor, with the same loader - a YM1510
guy
   / Hydraulic pressure from divert low? F22 #2
Plug in a hyd gage and check the pressure.
   / Hydraulic pressure from divert low? F22 #3
You also maybe able to adjust the pressure at the FEL joy stick. I had to increase mine this week so my FEL would pick my trailer up to install new axles
pressure relief valve on joystick wound all the way in. I dont have a gauge - ill see if I can beg borrow steal one from the local dealer. Any idea what the pressure should be?
   / Hydraulic pressure from divert low? F22 #5
I have no information on an F22 but a YM220/222, same horsepower range, relief pressure on 3 point is a little over 2200#. I would just guess yours to be in that range. Maybe there is somebody out there with an F series manual.
Well - I bought a gauge and installed it on the lift hose - 2200psi - and 1800 on the 3ph auxiliary out (the one you use for tipper trailers etc) - which is a bit weird that the 3ph is lower than the FEL.
2013 Chevy Silverado 2500 HD (A52748)
2013 Chevy...
Genie GTH-644 (A50490)
MAHINDRA MAX 24 HST COMPACT UTILITY TRACTOR WITH LOADER (A52748)
MAHINDRA MAX 24...
2015 FREIGHTLINER CASCADIA DAY CAB (A52577)
2015 FREIGHTLINER...
2020 KENWORTH T680 (A52472)
2020 KENWORTH T680...
