Advice on aftermarket air filter for '08 F250
   / Advice on aftermarket air filter for '08 F250 #11
There is a study available online about the efficiency of different air filter combinations. The very best was a AC Delco filter in a stock housing, the very worst was a KNN. Do not be fooled by the thought that the filter is so much cheaper, the filter is not free, the cleaning and oiling kit is not free.
Personally I would never install any air intake system, If there system is so good they would give a guarantee?
   / Advice on aftermarket air filter for '08 F250 #12
Look up MBRP on Bing or Google.com and find one near you that has a Cat Back Exhaust. Go with a 4in.
Go to some of the PowerStroke Forums and see what others are doing to there 6.4's
Doug
   / Advice on aftermarket air filter for '08 F250 #13
straight out of the box(FACTORY OILED!) installed, drove ~8000 miles and the intake and turbo looked like someone fed it mud, turbodiesels pull too much air for a K&N, they will pull the oil out and then eat the dust that the too dry air filter can't stop.
That is a good point. I have always had gassers.
But I did use a K&N in my supercharged mustang and never had a problem. It only made about 9 lbs of boost though.
   / Advice on aftermarket air filter for '08 F250 #14
the camero's had similar problems also, the air filter would foul the MAF with oil and cause the engines to run like crap!
   / Advice on aftermarket air filter for '08 F250 #15
A lot of vehicles have problems with the oil of the filter getting on the MAF. Now it is not the big of deal since CRC makes MAF cleaner.
   / Advice on aftermarket air filter for '08 F250 #16
sure IS a problem when the oil is in the engine instead of on the filter. it can't stop dirt/dust with its oil in the engine instead of on the filter!
   / Advice on aftermarket air filter for '08 F250 #17
They do (K&N anyway) million mile Guaranty.
http://www.knfilters.com/warranty.htm
Have run K&N in the past with no adverse effects...except for gas mileage; hard to stay off the loud pedal with the awesome sounding intake noise
   / Advice on aftermarket air filter for '08 F250 #18
Hi everyone,
I am looking for suggestions on an aftermarket air filter for my 08 F250 with the 6.4L diesel. I am comparing K&M, AFE and others.
Your experiences and advice would be appreciated. I am mostly looking for a boost in MPG.
Thanks, Eldon
Check around on some Ford diesel forums. I found that the general consensus is against K&N.
Although I bought a K&N intake kit for my '97 F Super Duty Powerstroke, I opted to keep the hardware and swap the filter out for a Donaldson paper unit. It's working just fine for my application.
   / Advice on aftermarket air filter for '08 F250 #19
In the past I have used the k&n oiled filters, now I have an afe pro dry filter in my Tundra. It has worked very well.
2018 Cadillac Armbruster 70 IN Limo - Only 49K Miles - Luxury Transport, Clean, Well-Maintained (A56435)
2018 Cadillac...
2024 INDUSTRIAL  MINI EXCAVATOR (A58214)
2024 INDUSTRIAL...
2013 Chevrolet Silverado 1500 Ext. Cab Pickup Truck (A55973)
2013 Chevrolet...
2014 Dodge Avenger Sedan (A56859)
2014 Dodge Avenger...
2007 JLG 660SJ TELESCOPIC BOOM LIFT (A52709)
2007 JLG 660SJ...
2004 AGCO Gleaner 3000 Corn Header (A56436)
2004 AGCO Gleaner...
