Gravely 526 Flywheel for 8HP Kohler
   / Gravely 526 Flywheel for 8HP Kohler #1
Gary C.
Eastern Ohio
Yanmar 2000 & Yanmar 1610
Hi, I'm working on a Gravely 526 walk behind tractor for a friend that had a bad rattle in the motor. Turns out the flywheel is cracked on either side of the crankshaft hole. Anyone have a used one laying around please let me know. It's for a Kohler K181 series with a spec. #30675D. A new one is way more than the tractor is worth. Thanks!
   / Gravely 526 Flywheel for 8HP Kohler #2
Welcome to the high prices of Kohler. Sometimes Kohler is insane with their parts prices.
Most of the time, cracked flywheels are caused by over torquing the flywheel nut or lubricating the bore or shaft when installing. That is a pretty common flywheel.
Ebay is you best bet. Gravely didn't use anything special so any flywheel for the same engine will be fine.
King Kutter TG72 Rotary Tiller Tractor Attachment (A51691)
King Kutter TG72...
CUSHMAN HAULER 1200 GAS GOLF CART (A51406)
CUSHMAN HAULER...
2021 Caterpillar 428 4x4 Extendahoe Loader Backhoe (A52377)
2021 Caterpillar...
1983 Case 580D (A47477)
1983 Case 580D...
2016 Ford F-550 Ext. Cab Flatbed Truck (A52377)
2016 Ford F-550...
2017 Ford Fusion Hybrid Sedan (A53424)
2017 Ford Fusion...
