Dr Dave
JC Witney used to sell dual wheel spacer kits, they used your stock wheels. Chevy 4x4 use the same wheel bolt patern, if they do not list Toyota.
Dave
Dave
Especially with oversize tires on it...Speaking of that... make sure your brake system is in good order when hauling those heavy loads.
Not sure if anyone posted anything about the frame, but if you live in a rust state then you might want to check it out. I have three coworkers who either had toyota buy it back or had them replace the frame. I would hate to do all that work and find out after. Good luck either way.
foreman Etexas said:Its a YOTA work it<img src="http://www.tractorbynet.com/forums/attachment.php?attachmentid=280637"/><img src="http://www.tractorbynet.com/forums/attachment.php?attachmentid=280638"/>
I have a 2001 Tachoma 4X4 that I run 61 miles one way to work, and haul firewood on it. I have side boards so I can stack to the cab height. I am running load range E tires on it from a daully, When we haul wood it from @25 miles away and the only problem I have is the bed bows in the middle till you can't shut the tailgate, I use a floor javk and bend it back. I don't see how you are going to haul more in the stock box no matter how much you beef up the suspension.
Randy
Yea, I saw a truck like that loaded down, the guy missed the turn because the front wheels weren't on the ground. Got to say that he didn't like the damage he did to the truck when it careen by me and went through a fire hydrant. His rear bumper was dragging the ground and the front tires were bouncing off the pavement.Its a YOTA work itView attachment 280637View attachment 280638
