I bent my steering rod. Is this the only part I need?
   / I bent my steering rod. Is this the only part I need? #1
rebelback
South Arkansas
2010 Case Farmall 45 HST
I managed to bend my steering/connecting rod pretty bad yesterday by getting hung up on an old stump. Everything seems to work okay other than when my right tire is pointed straight my left tire is pointed to the left. Is part #35 probably all I need? It shows it in two pieces in the diagram, but it is a one piece rod.
Official Case IH Online Parts Store and Case IH Catalog for Parts Search and Parts Look Up. Case IH Parts for Case IH Tractors, Case IH Combines, Case IH Tractors, Case IH Manuals, Case IH Parts
Also, does anyone know of a place online that might be a little cheaper than the dealers?
   / I bent my steering rod. Is this the only part I need? #2
Do you have a hydraulic press or know someone that has one, you may be able to straighten the one you have. Also a local machine shop may be able to help you. It is one piece, it is just the way it is drawn that makes it look like two.
Ken
   / I bent my steering rod. Is this the only part I need? #3
unless i'm missing something.. that just looks like a draglink rod to me. IE.. piece of tube and tie rod ends.
I usually MAKE those for my tractors when I get one come in bent..
I'd have no qualms torching a new tube section int he middle and joining the ends
That is indeed what it is, but I do not have the tools nor the expertise to accomplish this task. It is $134 at the local dealer. I plan to pick up the part Thursday.
   / I bent my steering rod. Is this the only part I need? #5
if you own a tractor.. it might be time to own a welder.. if you own a welder.... a torch is real handy... :)
good luck on the repair
   / I bent my steering rod. Is this the only part I need? #6
I had mine remade at a local metal shop for 30 dollars. He used my ends and ordered the hardened rod for the middle.
   / I bent my steering rod. Is this the only part I need? #7
i seen old tractors with water pipe for steering draglinks. :) funny what you see.
funnier yet what you can get away with!
2015 Nissan Altima Sedan (A50324)
2015 Nissan Altima...
2022 NEW HOLLAND 266BMM 66-INCH BELLY MOUNT FINISHING MOWER WITH SIDE DISCHARGE (A52748)
2022 NEW HOLLAND...
Redirective Crash Cushion Guardrail (A51692)
Redirective Crash...
2007 Ford Crown Victoria Sedan (A51694)
2007 Ford Crown...
2013 Cadillac Escalade Luxury SUV (A50324)
2013 Cadillac...
2004 Stage Line SL-250 Mobile Folding Stage Trailer (A50324)
2004 Stage Line...
