Diesel Tractor Dies After 30 minutes, Won't Restart w/o Ether
/ Diesel Tractor Dies After 30 minutes, Won't Restart w/o Ether #1
sourwood
Member
North Carolina
Farmtrac 665DTC, Zetor 7711, Long 460, Long 310, Satoh S370D, Iseki 4100F, Case 380CK, John Deere 420C
Tractor In Question: Farmtrac 665DTC, basically an Indian Copy of the Ford 5000 series, with a ripoff of the Ford 201 three cylinder diesel & Bosch Mico Injection system.
Problem: Tractor sputters and dies as though it is not getting fuel, it only does this after 30 minutes of operation and particularly while going uphill. The tractor then will not restart for a few hours, and then requires ether boost to start. Upon using ether, the tractor will startup, run rough, then even out and idle ok- even low idle. So long as you don't run it for longer than 30 minutes or try to drive up hill, the tractor is fine, will stop and start. Run it for 30 minutes and drive up a steep hill(I live in the mountains) and the tractor acts like it is not getting fuel and dies out.
Background:
I recently had a fuel contamination problem where both fuel filters got contaminated with water. This is where this began- the whole not getting diesel fuel type symptoms. Both filters were so badly damaged, I had to replace them at the same time. I bled the system as best I could and then used ether to finish bleed as I only had myself to do this with. It still died on me going up a hill, so I cleaned out the screen that is attached to the gas tank petcock. I still have the problem.
It is like the tractor suddenly isn't getting diesel and just dies.
Thoughts ? Suggestions ? And I don't mean burn it down for insurance money, either, guys. :)
Thank you in advance !
/ Diesel Tractor Dies After 30 minutes, Won't Restart w/o Ether #2
Did you drain fuel/ water, in tank. Try running with fuelcap off, eliminate a possible bad vent.
Dave
/ Diesel Tractor Dies After 30 minutes, Won't Restart w/o Ether #3
Dave
Look for a filter on input of the diesel pump., and then cut open the replaced filter to see if full of water . Drain the fuel tank into a clear container and see if water or jumk is coming out of tank. if so after empty take a cloth on a stick fixed so cannot come off and swab the inside bottom of tank. this dry cloth will collect any water left in tank. or show you what could be blocking the place where fuel is going into line to filters.
Don't know your brand of tractor but either isn't a good idea in getting started. Can end up breaking the piston top ring or damage the engine.
If all this is good maybe a compression check and clean the injecters foillow the method of bleeding the fuel system.
ken
1981 LINK BELT HSP 8028 (A58214)
1981 LINK BELT HSP...
1984 BOMAG MPH100R SOIL STABILIZER/RECYCLER (A60429)
1984 BOMAG MPH100R...
1996 Freightliner FLD112SD T/A Dump Truck (A55852)
1996 Freightliner...
LOT LOCATIONS (A59905)
1978 Gray 48RM Vertical Boring Machine (A59213)
1978 Gray 48RM...
2025 Ariens IKON 42 42in Zero Turn Commercial Mower (A59228)
2025 Ariens IKON...
