Parts breakdown for leak at injection pump on ford 1720
   / Parts breakdown for leak at injection pump on ford 1720 #1
jnhelton
new-holland 1720
Have a leak on left pipe outlet at the fuel injection pump. 99% sure its not the pipe connection but under the flange that pipe connects to. There's 3 oval oblong flanges that appear to be what each pipe fastens to. They each have a bolt at top and bottom. The bolts are 5 sided and would require some special wrench. Any chance just tightening the bolts will solve problem? Is there a o ring or gasket under each flange? Thanks
   / Parts breakdown for leak at injection pump on ford 1720 #2
I have the same problem what's the answer
   / Parts breakdown for leak at injection pump on ford 1720 #3
   / Parts breakdown for leak at injection pump on ford 1720 #4
There r 2 orings under each flange.. regardless of what ANYONE SAYS.. do not use any other orings but factory orings designed to go in that position..
Yes a special socket is required..
They are that way because it’s a safety and emission thing..
The flanges are “slotted” to set the equal delivery between cylinders and locked down w that bolt..
I rebuild them daily..and keep the parts in stock..
https://www.accessnewswire.com/newsroom/en/healthcare-and-pharmaceutical/slimjaro-vs-burnjaro-reviews-a-comprehensive-analysis-of-benefits-and-1044755
https://www.accessn...
New Wolverine72 In Skid Steer Brush Cutter (A53002)
New Wolverine72 In...
1994 Prevost Liberty Coach Motorhome (A51694)
1994 Prevost...
2007 Toyota Camry Sedan (A50324)
2007 Toyota Camry...
