Comparison Looking at L4600, Mx5100 and M5140
   / Looking at L4600, Mx5100 and M5140
Just got a quote for a M5140 Sychro-Shuttle, R4's, QA 1153 Loader, 3rd Function loader valve, filled rear tires and delivery for $29,200 cash. Working on getting a comparable quote for the MX5100. I am thinking it should come in around $26,000 for the same configuration with the exception of HST instead of the gear trans. Looking at the specs and driving both tractors, I think the M5140 is definitely $3K more tractor.
What do you all think of the $29,200 quote for that configuration. It works out to about 15% off MSRP including the Kubota $1,000 cash back incentive.
I appreciate your input!
Thanks,
   / Looking at L4600, Mx5100 and M5140 #12
I have an L4300, whish is close enough to an L4600. I also have an MX5100 and I'll say my MX5100 outclasses the L4300 is a few big ways. It has a beefier front axle that holds it down and makes it much easier to handle a heavier rear implement. It has more power and while it's only a few more HP, the extra cubic inches and turbo give it a real power advantage. I dare say the MX5100 is the best small tractor I ever owned and I am really fussy.
I don't know the M5140 but I suspect it's the same engine as the MX5100 and close enough to handle about the same. I'm not sure what is best for you but I know it's either the MX5100 or M5140 and not the L4600. And I prefer gear drive as well. It works great with the MX5100 and also has a shuttle you can F-R use.Get over the gearshift issue since it hardly is noticable. Just my two cents.
   / Looking at L4600, Mx5100 and M5140 #13
Having traded in a synchro-shuttle in on a hydraulic-shuttle and driven both for a few years, get a hydro-shuttle on the M5140 if you can. It is far easier to use than one can imagine. Nothing wrong with a synchro-shuttle mind you, my brother just bought one, but for me it was a great improvement.
Decision just got tougher, quote on MX5100 came in at $24,500 so I am looking at $5k more for the M5140. I really like the 5140, but $5k difference is more than I anticipated. Any thoughts, opinions, guidance on the 5140 worth the extra $5k?
   / Looking at L4600, Mx5100 and M5140 #15
$5K more for a 5140 doesn't seem worth it to me.
   / Looking at L4600, Mx5100 and M5140 #16
I went back and read your list of uses and I just can't see spending the extra money for something it appears a much more economical and well equipped tractor will do. $5000 will buy some really nice implements.
   / Looking at L4600, Mx5100 and M5140 #17
20ac. It would be between the MX5100 hst 4x4,or the GrandL 5240/5740,probaly the GrandL. I just got rid of my M5040 is was a tough tractor but just for mowing alittle here and there and the driveway and such I think would like the small frame tractors over the M series unless doing hay or something. The 5 grand could get you a new mower,box blade,landscape rake,etc. Same HP,do you need a bigger,heavier,tractor?
   / Looking at L4600, Mx5100 and M5140 #18
its a no brainer go with the mx5100,$24,500 is a great price.i gave $24,000 for my mx5100 hst 4x4 w/la844 quicktatch loader.
   / Looking at L4600, Mx5100 and M5140 #19
ditto. I still say the mx can do a suprising amount of work. Thats an awful good price too!
   / Looking at L4600, Mx5100 and M5140 #20
Between those two, I'd get the MX5100..
2013 FELLING  SKINNYNECK TA LOWBOY (A53843)
2013 FELLING...
2011 JACK 130BBL (A53843)
2011 JACK 130BBL...
NAPA 230V AIR COMPRESSOR (A53843)
NAPA 230V AIR...
2002 Genie S-125 4x4 125ft Telescopic Boom Lift (A52377)
2002 Genie S-125...
2013 Jeep Patriot Sport 4WD SUV (A53424)
2013 Jeep Patriot...
