Kubota F2560 4WD
   / Kubota F2560 4WD #1
Arlen
South Lyon, Michigan
F2560 4 WD 2002
I just brought home a used Kubota F2560 4WD mower with 1431 hours. I was mowing for a few hours and noriced some fluid on the left side of the mower as I stopped out by the pasture area. I looked under the mower to check the fluid bubble and it was over half full. I got back on the mower and continued to mow...as I turned right at the end of animal pen, I noticed a large amount of fluid on my left side, I shut down the unit, slid under it and could see a lot of fluid dripping from I don't know where??? I cleaned off the whole under carraige with a rag and waited, but no more fluid was dripping. I looked at the bubble again and it was below half... I noticed that the drivers left side tire had a lot of wetness on the inside of the tire and the rim...enough so that there was a tiny puddle on the inside of the bottom of the rim where it was gathering in the rim groove. The fluid dripping under the unit was not coming from the motor, but somewhere forward, as the motor was not dripping at all and the fluid seemed to be coming from the forward area??? I am stumped...does anyone know anything about these units and can you shed some light on my dilema??
Thank you,
Arlen
P.s. My other F2560 is newer with only 850 hours on it, is not a 4 Wd and has never had any problems other than tires and blades.
   / Kubota F2560 4WD #2
About the only thing you can do is to have someone operate the machine and wach to see where the oil is coming from. Sincs you notice the puddle when you are turning check the power steering lines.
Bill
   / Kubota F2560 4WD
Bill
Thank you for the tip. I did that today and I found one leak in one of the hoses, so I'm taking it to a place here in town tomorrow to get a new one made. The zip tie that was holding it to another line, cut into it and that is where I found the leak............I sure hope there's only one hose leaking???? :eek:)
JOHN DEERE LOT NUMBER 121 (A53084)
JOHN DEERE LOT...
2008 Ford F-750 Crew Cab Pro Patch TCM-425-135 Asphalt Patcher Truck (A51692)
2008 Ford F-750...
2014 INTERNATIONAL MA025 (A52472)
2014 INTERNATIONAL...
1986 ASPT 30ft S/A Pole Trailer (A51692)
1986 ASPT 30ft S/A...
FAKE (A52472)
FAKE (A52472)
CAT FORKS W/ QUICK COUPLER (A52472)
CAT FORKS W/ QUICK...
