HyGard vs. low vis HyGard in 3520 ehydro
   / HyGard vs. low vis HyGard in 3520 ehydro #11
Hiya,
The service manual for 3x20 series calls for lo-vis fluid in temps from -40 to 104 degrees, standard hy-guard covers from -15 to 122. Can't see temps in WI getting too much above 104, I would use the lo-vis.
Tom
   / HyGard vs. low vis HyGard in 3520 ehydro #12
Hiya,
Tom
I can't imagine using a 3520 much when it is colder than -15. I'd pocket the savings & use regular HyGard.
   / HyGard vs. low vis HyGard in 3520 ehydro #13
Hiya,
I've used open station tractors to clear roads up in the mountains in snow country when it's been colder than -20, -15 would have felt good.....
Tom
Even though the manual shows you can use either I just pulled the dip stick and noticed the following embossed in the dipstick itself, "use low vis HyGard".
So that settles it for me........Low Vis HyGard it is.
Thanks for your inputs. I'm just not sure if it is required because it is Ehydro vs HST?
2018 Toro Workman GTX Electric Utility Cart (A51691)
2018 Toro Workman...
NEW HOLLAND 706 30 INCH 3PT DIRT SCOOP (A53473)
NEW HOLLAND 706 30...
2019 INTERNATIONAL LT625 TANDEM AXLE SLEEPER (A53426)
2019 INTERNATIONAL...
Koyker Loader DoubleTine Bale Spear - Versatile for Round and Square Bales (A53473)
Koyker Loader...
1987 Ford F800 Fire Truck (A51692)
1987 Ford F800...
