Drilling out SS rivits and what does HSO mean on a drill bit?
   / Drilling out SS rivits and what does HSO mean on a drill bit? #1
Cliff_Johns
Elite Member
Northern Illinois
JD 4110
I'm trying to drill out some stainless steel rivits. I'm going through
my pile of old drill bits acquired from various places and found some
that are marked HSO instead of HSS. The markings are quite clear.
So 2 questions:
First, what does HSO mean on a drill bit?
Second, To drill out the rivits, I figure use slow speed and a little
wd-40 -- this has to be hand drilled. Any other advice?
Cliff
   / Drilling out SS rivits and what does HSO mean on a drill bit? #2
Is HSO the brand?
And if the rivets are anything besides pop rivets, I'd probably use a cobalt bit anyways.
   / Drilling out SS rivits and what does HSO mean on a drill bit? #6
Is there a size on the bit?
could the O be a letter "O" which is 0.316"
HSO = High Speed letter O
i have seen many bits marked HS and then the size
or
maybe it is for Oxide
black oxide bit ?
have never read or heard of an HSO category drill bit.
tom
   / Drilling out SS rivits and what does HSO mean on a drill bit? #7
About removing the rivets.
if you are not worried about a painted surface or emery wheel marks. i remove alot of s.s. rivets at work by using an angle grinder with a 60 or 80 grit flap disc.
grind the rivet front or back flush to the sheet metal and use a drift punch or a center punch to remove the other half.
drilling many times will spin the rivet if you use too much pressure and will usually mark up the mounting surface too.
tom
Specifically, it says HSO then on the next line it says 3/16
or
black oxide bit ?
tom
It's on a painted surface that I don't want to dammage, otherwise, I suppose that would work pretty fast.
Cliff
snip . . .
tom
   / Drilling out SS rivits and what does HSO mean on a drill bit? #10
how about using a dremel type grinder...or a stone in a drill...just brainstorming...I almost always grind out a rivet than drill it out...
2016 Ford F-550XL (A53314)
2016 Ford F-550XL...
2021 Allmand Bros Maxi-Lite II 20kW Towable Light Tower (A55973)
2021 Allmand Bros...
Toro Sand Pro 5020 (A53316)
Toro Sand Pro 5020...
Galvanized Livestock Gates - 4FT x 18FT (2x Gates) (A55301)
Galvanized...
2011 Toyota Camry (A55758)
2011 Toyota Camry...
2017 Ford F-150 (A53422)
2017 Ford F-150...
