JD 2155 Leaks..Please explain to a newbie!
   / JD 2155 Leaks..Please explain to a newbie! #1
sirrobinhood
Bolingbrook,IL
Kioti DK55
Hello all,
I looked at buying a JD 2155...I dont know too much about this stuff..
There is a box under the right side of the tractor with two hoses (Hydraulic) going into.This is leaking real bad.
What is this box and what would it take to repair it. Also where the arms on the hitch move up and down, they are leaking hydraulic fluid also. What would that take to repair also? Thanks for any info!
   / JD 2155 Leaks..Please explain to a newbie! #2
Are your brake pedals connected to the box? That would be your brake valve? Where is leaking at on the box. Your 3pt leak is load shaft seals. Pop arms off. Drain hyd. Oil push the arm in and replace inner seal on both
sides. Not too bad to do.
   / JD 2155 Leaks..Please explain to a newbie! #3
Can you post a picture?
   / JD 2155 Leaks..Please explain to a newbie! #4
Is the box an enclosure for a loader valve? Does it have hydraulic couplers. Might want to pay a JD mechanic to check it out for you before you buy.
   / JD 2155 Leaks..Please explain to a newbie! #5
Is the tractors leak either one of these parts schematics??
   / JD 2155 Leaks..Please explain to a newbie! #6
I just replaced the load shaft seals on my 92 2155. Thanks for the info! They were very easy to change.
   / JD 2155 Leaks..Please explain to a newbie! #7
Do you recall where you got the load shaft seals at and possibly the part number? My JD 2155 seems to have developed the same problem, but can't find the identical schematics on the John Deere parts website. Any help would be appreciated.
   / JD 2155 Leaks..Please explain to a newbie! #8
You can find the parts schematics titled: PARTS FOR LOAD CONTROL
   / JD 2155 Leaks..Please explain to a newbie! #9
Thanks Tx Jim - With your help I got the correct parts and changed them out.
   / JD 2155 Leaks..Please explain to a newbie! #10
I'm glad all went well.Jim
IRanch High-End Electric Tricycle (A57149)
IRanch High-End...
Trailmobile Van Trailer (A56436)
Trailmobile Van...
2020 John Deere MX8 8' Rotary Cutter, S/N 1P00MX8HJKP045954, 540 PTO, Hydraulic Rear Wheels, Asset# (A59076)
2020 John Deere...
RAKE ATTACHMENT FOR MINI EXCAVATOR (A58216)
RAKE ATTACHMENT...
Enerpac RCS302 30-Ton Low Height Hydraulic Cylinder, 5" Tall (A59076)
Enerpac RCS302...
2018 Bandit 15XP Wood Chipper (A57453)
2018 Bandit 15XP...
