retiredmgn
Gold Member
- Joined
- May 8, 2010
- Messages
- 454
If you have the upright Brinkman with 2 grates and a water pan, you should be able to get a good slab of ribs; just make sure that you can maintain a temperature of about 250 degrees. If you maintain the water pan, it will mitigate the heat so it doesn't get too hot. My concern with the Brinkman I had was keeping the temperature up.
I take my ribs (baby backs usually) and rub them down with my special rub blend; Cains makes a good rub, and Bad Byron's Butt Rubb is good also, just a tad hot. I first spray them down with some olive oil, and apply a generous amount of rub and them I put them in an oven bag over night. Set them out an hour or so early to let them warm up a bit before putting them on the grill.
I use a mixture of well seasoned Mesquite wood, Pecan and blackjack oak. I put on enough to make a lot of smoke early, and don't add any more. Mesquite is pretty strong, and it will make your meat bitter if you use too much, as will green wood. I do not soak my wood.
It's up to you to decide when they are done; usually always less than 3 hours in the egg. Full slabs of spare ribs usually take about 4 hours or less.
Good luck.
"the upright Brinkman with 2 grates and a water pan"
Yup, that's the one. My best guess is too much smoke which causes the bitter taste. And I did soak my wood as the instructions on the package suggested.
This idea of pre pressure cooking is interesting.
I've not run into this rub you speak of. Not sure how I would approach that...
"Excuse me, do you have Bad Byron's Butt Rubb"?
On one hand someone might consider it a rather personal question of hygiene. Or perhaps they would just lead me down to ointments and suggest, "Bag Balm".
Probably best if I just quietly peruse the seasoning isle.
Thanks for the tip.
