Sprayer question
   / Sprayer question #11
I suggest you avoid the 12 volt pump. I have a 3.5 hp gas, and it takes many hours to do my 4 acres with it.
   / Sprayer question
Is the 12v just too weak?
   / Sprayer question #13
I have a 15 gallon 12v pump and I am thinking that the reason they dont put them in anything larger than 25 gallon is durability. I dont think they will last long in constant use. I think they are made mostly for spot spraying. If I were needing a large capacity application, I would look for one of the 275 gallon tote tanks that you can get for free from some manufacturers who use the product in them and cant dispose of them. I got one that was washed clean simply for pickup (they even loaded it for me) Anyway, the tank can be free just for calling around and then add either a gasoline chemical pump or a PTO driven one if you have a tractor. If on a tractor, you could make a simple 3 PH frame and mount it. You should be able to get all you need at TSC, Farm Co-op, etc.
If you must have a 12v pump then buy a couple of spare pumps when you purchase it.
   / Sprayer question
Yes.
I am sure there are people who do it, but I would not recommend a 12 volt sprayer for more than an acre.
Good to know. Once I get one, I'm gonna wear that puppy out!
   / Sprayer question
The specs you are wanting are unrealistic.
David
Kb7uns
How so? It would be like any other sprayer on the market, just a larger than average holding tank of 100 gallons.
   / Sprayer question #19
Specs are fine, but the expectations for price and possibly performance from the rinkydink pump are unrealistic. I'm a farmer and spray for a living. I've got a hundred gallon trailed ATV sprayer. There is a higher spec electric pump but its about $350 just for the pump. Throw in a 100gal tank and a trailer capable of hauling it without falling apart after a hundred rough or soft acres?
   / Sprayer question
Well you may be right on price, but I have been unable to find these sprayers around the net for any price.
2022 Ford F-550 Cab and Chassis Truck (A50323)
2022 Ford F-550...
2000 Thomas Built Saf-T-Liner MVP-ER Transit Passenger Bus (A48081)
2000 Thomas Built...
McCullough FG600MK Generator (A50860)
McCullough FG600MK...
2014 VOLVO VHD DAY CAB (INOPERABLE) (A50854)
2014 VOLVO VHD DAY...
2011 Kia Optima Sedan (A50860)
2011 Kia Optima...
2009 Chevrolet Impala Sedan (A48082)
2009 Chevrolet...
