First off thanks JC-jetro for the reply,
I took it apart and found that the fwd shift case had a broken stop tab.Which lets the shift pin linkage (which is also worn out) go to far, letting the detent springs and ball fly out into the transmission.So far I found the outer spring,the broken stop tab, and the ball.I am still looking for the inner spring. I ordered the new parts which they have made an upgrade for it which is an external stop plate kit,the new 4wd shift case , a new shift pin/lever, and a gasket for a total of $240.19.
My tractor is an 1988 1720 which the upgraded stop plate came on the 1989 models I think. My tractor did not have part # 38 on the attachment, part 33 had the broken stop tab and part 27 was wore on the shift pin
Thanks and I hope this will help someone else, 1720ford
