New Home Heating Ideas
   / New Home Heating Ideas #11
Whereabouts in se mi? I am north of Ann Arbor and hoping someday to do what you are doing now. Have you looked at building with ICFs or SIPs? Just a thought.
   / New Home Heating Ideas #12
I would check out Geothermal heat pump. We have two units to heat and cool our home. One does the upstairs and one does the first floor. You have enough land you could use a horizontal loop field and just move heat from the ground into your house. There is a 30% federal tax credit which helps on the cost.
   / New Home Heating Ideas #13
Hey guys!
My wife and I are in the processing of building a new home out on 20 acres in southeast Michigan. Currently we use natural gas and electricity for utilities in town and our monthly bill is about $200. Out at the new place natural gas is not an option so we're stuck with propane at $1.89 a gallon. The size of our house is going to be 2800 sq feet with 1400 sq feet in the unfinished basement (9 foot concrete walls). My neighbor across said his monthly utilities bill is $600. Ouch! And his house is about the same size as ours (new one). I've been doing some reading on Geo Thermal as an option but up front costs are big. I can probably roll it into my mortgage though which might work. I was also thinking about only using propane for heat in the winter and then all other appliances could use electricity. Maybe a pellet burner?? I'm not sure what to do. Can anyone offer any advice?
I think you should stick with the tried and true systems....Alot of the relatively new stuff just opens the door to be taken advantage of......Times change and you will change with them, whereas one of these `nifty` new ideas age in place.....and many times end up being replaced at additional cost Tony
Tororider,
I'm north of Ann Arbor also around the Brighton area. Where are you? Nice Deere by the way. I have a 3320. I'm not familiar with ICF's or SIP's.
dave1949 said:
I lived in NW Ohio (Toledo, Bowling Green, Fremont) until I was 36 years-old. I would definitely need AC if I lived there. My Mom, who still lives in BG, just had a hot and miserable summer, so I suppose you did also.
The upfront cost of geothermal is high, but a standard air heat pump is very workable in your area. Plus, the ducting and mechanical systems in the house are close to being the same for geothermal or standard air heat pump. You could start with a regular air heat pump and if that doesn't suite, continue on with a geothermal-supplied unit later. Just reserve space in the yard for the type of geothermal system you would choose.
I am not knowledgeable enough about heat pumps to know if your best choice is to pair the AC heat pump with a furnace or use one of dual-purpose heat and AC units. I think a lot must depend on the heating/cooling degree days for your location.
Right now (and planned through 2016), you can get a 30% federal tax credit on geothermal systems. It is worth checking. Perhaps Mich. has it's own program too.
Federal Tax Credits for Energy Efficiency : ENERGY STAR
It was a hot summer! My wife had the AC unit working overtime! I like your idea about starting with a regular heat pump and seeing how it does. The 30 percent federal tax credit will help alleviate some of the costs too. I was unaware of that credit... Thanks!
   / New Home Heating Ideas #16
The way I read it, the credit is only for a geothermal system, not a regular air to air heat pump. Your final out of pocket costs might not be that different with geothermal, but since it is a credit against taxes owed, that varies from person to person. You can carry over any unused credit for several years if you don't owe enough income tax to use it all in one year. You really need a knowledgeable heating and cooling contractor to give you comparative installation prices and annual operating cost differences to make a reasonable comparison.
For example, if the geothermal system costs more, but you can use the tax credit AND your annual electric bill is lower than with a standard heat pump, maybe after 10 years you break even on the costs. That's the sort of comparison needed to help you decide and it's very location dependent.
   / New Home Heating Ideas #17
We have geothermal. That' what works best for us. We also have a pellet stove. The pellet stove is not so economical but is very good back up heat. We can run the pellet stove from our portable generator but not the geothermal.
   / New Home Heating Ideas #18
You need to contact a heating engineer called Doug Rye he is out of Arkansaw he has a web site and is an advocate of geo-thermal. I have had mine since 1990. It is the cheapest way I have to heat my house. I have hot water boiler and a wood stove but the geo is the most econimical there are more geo systems in Canada than the US and it has been around since the early 1900. Doug lists his phone # and will talk you thru what you need he will calclulate you furnace and a/c size if you send him your plans,
   / New Home Heating Ideas #19
A well made and insulated home of any construction type can benefit from using nature to your advantage. Orienting the house to take advantage of the free heat from the sun in the winter, and having overhangs or deciduous trees shade your windows in the summer can cut bills by quite a bit.
   / New Home Heating Ideas #20
Check with your electric company and see if they offer rebates, mine has rebates for heat pumps and offered free Marathon water heaters for all electric homes. We have a seperate meter for heat pump and water heater, rate is half of normal rate, it is hooked to a radio controled switch and can be shut off for 15 min at a time by utility, during peak loads.
Dave
FAE UML/SSL 150 VT BL HYD MULCHING HEAD (A51406)
FAE UML/SSL 150 VT...
JOHN DEERE 5125R (A53084)
JOHN DEERE 5125R...
2018 Ford Fusion Sedan (A55853)
2018 Ford Fusion...
Dvorak Model 3072A Hydraulic Ironworker S/A Towable Trailer (A55851)
Dvorak Model 3072A...
2019 Ford F-150 Crew Cab 4x4 Pickup Truck (A53422)
2019 Ford F-150...
2842 (A54756)
2842 (A54756)
