Lawn sweepers?
   / Lawn sweepers? #1
oscer
Central Pa.
JD 4110
Hi fellas, I have a row of chestnut trees in the back yard and although I like having them there for the wildlife the reall leave a mess ever fall. so I was planning on buying a lawn sweeper this year but after looking at them they all seem to be made pretty cheaply. I did a search and read some threads some folks seemed to like the brinlys but when I looked at one at Home Depot I thought it looked just as cheaply made as the Agri Fab I had seen at tSC. I think the Craftsman looks to be the most well built of any I have seen but I was wondering if I could get some feed back from you folks? Thanks oscer.
   / Lawn sweepers? #2
I bought a 42" from Sears after looking around. As you said it just looked as good or better than most sweepers in that range.
I've had mine for 8 years now. It don't see heavy use but has worked fine with no issues. It dumps from your seat with a rope, works well enough.
Sears had 2 styles in the 42" range one a 5 : 1 ratio and I bought the 8.5 : 1. A friend of mine worked at Sears at the time and told me there's a big difference in the faster turning brushes and not a big difference in the price.
I have to admit I don't shop Sears as much as I used to for several reasons but have been more than pleased with the sweeper. Good luck to you.
   / Lawn sweepers? #3
I have used a Craftsman for about the last 15 years and it has not given me any trouble. I even ran it over once with my old Allis Chalmers model C when I cranked it while it was in gear. After straightening out a few bends, that sweeper has worked like the day it was new. I got it a garage sale, for about $25 I think. I remember that it did not work very good at first, but after I adjusted the height, it worked much better. What I usually do is hook it to my Wheelhorse, 12 hp gear tractor and put the tractor in the highest gear. I bush-hog an area out back of my lawn and I just keep making rounds from the trees up front to the bush-hogged area out back. It is nice to be able to just pull the rope to dump the load without even slowing down. I use a Farmall cub with a light snowplow to push those leaves into a pile back on the "rough". I dump my wood ashes onto that pile over the winter, which makes a nice compost to spread on the garden in the spring. I am looking forward to the leaves this Fall, they are already starting to fall in a few areas.
   / Lawn sweepers?
Thanks for responding Steave, I think a read that someone had trouble with the high gear ratio, that when they pulled it it would skid instead of turning the wheels. It doesn't sound like that's an issue with yours and 8 years of service sounds real encouraging. oscer.
   / Lawn sweepers? #5
I suppose if you set the brushes down into the grass very deep it might cause it to slide the wheels but that would happen with any of them. I've never had that issue with mine. Works great.
If I let the grass get to high and have to use the sweeper I usually wait till the next day to sweep. The grass dries and not near as many trips for dumping. Also better dry for the mulch pile. If you pile grass while green it will mildew. As for the leaves get um when they fall.
I'm not sure why it has such a large hopper because it seems to only fill about half full maybe a little more before it needs dumping. I've talked to people with different brands and its the same. It will keep picking up till full but does better to dump often.
   / Lawn sweepers? #6
I bought a 42" lawn sweeper from countrylawn-garden.com and have had it for 3 to 4 years. No problems with it. I have towed this behind my Kubota B3030 and it appears well built and has served me well.
   / Lawn sweepers?
Wolc123, I didn't see your reply earlier, thanks, hey I ran over my 031 Stihl chainsaw a few years ago bent the top handle bar all to... I stuck a digging iron in the ground through the handle bar and used it for leverage to straighten it back out , then went back to work. I still have that old Stihl too.
   / Lawn sweepers?
Nik, do you know who made it? There's one at the local Tractor Supply made by Ohio Steel ( I doubt it is in Ohio though, Kinda like Pittsburg Tool, they are made along way from Pittsburg ) but they don't have one put together for a display so I don't know what it is like.
   / Lawn sweepers? #9
I bought a 48" one from Northern Tool. It worked very well, but in less than 2 years the metal cog on the brush spindle completely stripped the plastic gear on the wheels. Perhaps I was running it on ground that was too rough, but it seems bad design anyway.
Ditch Witch 6510A Trencher - Deutz Diesel, Backhoe, Cable Plow, Front Blade (A53473)
Ditch Witch 6510A...
Massey Ferguson 1734E, 4wd, Hydrostatic Tractor (A52384)
Massey Ferguson...
2013 Nissan Pathfinder SUV (A51694)
2013 Nissan...
2019 John Deere 5090R Tractor (A52384)
2019 John Deere...
Exmark LazerZ Zero Turn Mower (A53117)
Exmark LazerZ Zero...
2017 John Deere 30G Mini Excavator (A51691)
2017 John Deere...
