YM1500 for sale whole or parts
   / YM1500 for sale whole or parts #1
kathol233
flippin, ar.
many
Hello, I have a ym1500 I recently purchased at a consignment auction, when I got home with it and started cleaning it up I found that the block has been broken and repaired and the repair is seeping water. The tractor does run.
I have it for sale as a whole tractor or I will sell parts from it to try and get a little of my investment back.
If anyone might be interested the tractor is located in north central Arkansas and I can be contacted at: kathol233@flippinweb.com
thanks,
Bruce
you can fix that.it still a good tractor.
This had a piece about the size of a baseball broken out of the block. Someone then welded it back in.
How do you fix?
Bruce
   / YM1500 for sale whole or parts #4
you can weld that.i have welded a lot of them.my dad was a old seabee and we welded big cast pump in the old days.he let me welded with him when i was 13 all stick in the old day.i am 54 now.now with mig welders and co2 it not that hard.if i can help you let me know you can call me.my dad seen i was not good at school so let me go to work.i loved being a welder. i did not like school so i am a better welder then speller. the guy that welded it the first time my not have been good at it.i made a lot loader for ym1500s. i have a ym1700 welded block that i use run like a top.hop that helps.Ray
   / YM1500 for sale whole or parts #5
What are you asking for it?
I'll try welding it and see what happens.
I was hoping to get $800.00 out of it.
   / YM1500 for sale whole or parts #8
Coldwater is correct. cast iron can be welded with great success. It might require a specialty shop, but it certainly can be done.
   / YM1500 for sale whole or parts #10
i was thinking the same thing. The tires are worth an easy $300, the trans if working is worth that $800, the radiator an easy $50. and on and on. I dont think you have to worry. someone will snap it up for parts. Esp if it runs right now and just leaks!!
New Holland B95 Backhoe (A50490)
New Holland B95...
2022 John Deere HD50F Draper Head (A53342)
2022 John Deere...
2015 Toro Multi Pro 1750 175 Gallon Turf Sprayer Cart (A51691)
2015 Toro Multi...
2017 Ford F-250 Crew Cab Pickup Truck (A51692)
2017 Ford F-250...
Single Axle Rear Truck Frame (A51692)
Single Axle Rear...
