   / Harbor Freight Tools that don't suck #2,971
I bought a laser thermometer and use it for, of all things, the perfect barbeque. In this thread I have posted more of the details--search for it-- but I can do ribs and chicken better than I ever have using the thing.
I was wondering that myself. Can't run much stuff with only 800 watts available.
Ken
I used mine this weekend for a trail maintenance project at the local state park. It was perfect in that it was light enough to carry in and powerful enough to run a Sawzall. It was also quiet enough that it was not a distraction. Several people were amazed when I told them what I paid for it.
   / Harbor Freight Tools that don't suck #2,976
Ok, I see. I could only run a drill or lightbulbs at that rating. My lowest rated saw is 8 amp (960 watt) so I didn't consider that use.
Ken
   / Harbor Freight Tools that don't suck #2,977
Why half a dozen? :laughing:
Well I didn't get around to it due to other obligations. But the purpose for a "half dozen" is that I like to be able to help people out.
This small generator is just about right to power a small fridge based on:
I bought one of those little two stroke gens and I don't think it is too loud when you consider you're not paying the Honda price. It is definently quiter than the small chinese four stroke.
I found the generator adequate to pull a full sized refrigerator/freezer but that is all. Don't try to run above its' capacity or it will pop the breaker. Additionally I found it to be set too slow. I attached a voltmeter to it with a 100 W lamp as a partial load and found it was only putting out 92 V. I adjusted the voltage/speed screw and it now runs better and puts out 110V.
Or definitely a mini bar fridge.
To be the man with the power for 6 households for the measly sum of $500 is not to bad when the power goes out. I get a good feeling when I'm able to do things like clear the widows driveway after a big snowstorm, chop up the downed tree, pull the little cars out of wherever they are stuck, etc.
Plus if I've several small generators to lend I don't feel bad about saying NO to lending my bigger generators.
   / Harbor Freight Tools that don't suck #2,978
good to know.ill have to try it next time it comes in.
Here is the link to their "Digital Savings" website where there has always been a 20% off a single item coupon [as well a others that rotate through] every time I've accessed it.
Digital Savings
Thomas
   / Harbor Freight Tools that don't suck #2,979
Hey guys... I was thinking about buying a set of gear pullers, so was checking out what HF had to offer. I found these, and I GOTTA HAVE 'EM!!! :cool2:The first set of pullers I have ever seen that you could use indoors AND outdoors!! :laughing:Who says HF just copies other companies designs. I would be willing to bet a 800 watt HF generator against a doughnut that NO other tool seller offers an indoor AND outdoor puller set.:D
I haven't bought 'em yet, so I can't say they don't suck, but I will let you know as soon as I get 'em
   / Harbor Freight Tools that don't suck #2,980
Whatcha get when you let secretaries transcribe (and maybe edit) tool descriptions - I'm thinkin' whoever did that thought "inside" and "outside" weren't as sophisticated sounding as "indoor and "outdoor" :=)
2013 PRIME TIME RV LACROSSE (A58214)
2013 PRIME TIME RV...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
2021 Unverferth 432 Rigid 4 Row 36-inch 3PT Ripper Bedder (A56436)
2021 Unverferth...
LOT OF ELECTRIC HEATERS (A58374)
LOT OF ELECTRIC...
2013 FREIGHTLINER CASCADIA (A58214)
2013 FREIGHTLINER...
BLUEHAWK 17CU FT STEEL LAWN MOWER TRAILER (A58374)
BLUEHAWK 17CU FT...
