Suggested maintenance on recently purchased B8200D with 800 hours .
   / Suggested maintenance on recently purchased B8200D with 800 hours . #1
modaddysdotcom
ypsilanti
Kubota B8200D
I purchased for $4500 a used working Kubota B8200D with BF300 loader today as a project tractor to learn on. Any words of wisdom or technical assistance on what to do to bring it to peak operating would be much appreciated. I have owned and worked on cars and diesel trucks for 40 years but I am very excited to finally have tractor other than my trusty Sears GT. Normally I change all of the fluids in a new purchase but I have no clue what this tractor takes. That would be a good start as my loader operates quite slowly and probably needs a transfusion.
   / Suggested maintenance on recently purchased B8200D with 800 hours . #2
Definitely change all fluids to establish a base line for maintenance. I highly recommend purchasing the WSM (work shop manual) from Messicks or on Ebay. All fluid specs are listed, plus -with your mechanical experience- you will be able to do a lot of PM and repairs on your own. Good luck and enjoy your tractor.
   / Suggested maintenance on recently purchased B8200D with 800 hours . #3
I used to have a B8200HSTD for 12 years. GREAT tractor. Built like a tank, albeit a little underpowered with only 19hp. I know the guy who bought it from me; it is still going string!
Remember those hour meters roll over; it may be more than the 800 shown.
The owners manual is still available, and has all the info you need.
I would change all the fluids and filters, paying attention to clean the strainer in the hydro circuit. I used Delo engine oil, and Kubota UDT or compatible for hydro(you can get filters, oil, and hydro fluid from NAPA etc).
Make sure to grease all the zerks; a few are hard to see on the HST pedal, clutch pedal, and range lever... Every 10 hours....
Hydro change is easy; drain the system, spin on a new filter, and clean the strainer(banjo fitting on right side of tractor, kind of below where the range lever is). Just be prepared to catch 5 gallons of hydro fluid in your oil pan...
   / Suggested maintenance on recently purchased B8200D with 800 hours . #4
I don't know if it is applicable to your model, but if you have mechanical valves, factory recommends that they get adjusted at 800 hours--at least on my Kubotas.
   / Suggested maintenance on recently purchased B8200D with 800 hours . #5
i'd change all fluids and filters at a minimum.
grease all fittings.. check for wear and adamage.. fill tires.. check wear surfaces / items.. etc.
clean up electrical connections including battery and terminals... if serviceable battery.. add distileld water if needed.
change coolant out.. make sure to use a sca/dca coolant if it needs it ( i'd use one anyway even if it said it didn't have to have it )
2019 Ford F-150 XL (A50120)
2019 Ford F-150 XL...
2016 Chrysler 200 Sedan (A50324)
2016 Chrysler 200...
2012 Ram 4500 Versalift TEL29N 29ft Bucket Truck (A50323)
2012 Ram 4500...
2004 Ford F-250 Pickup Truck (A50323)
2004 Ford F-250...
2014 Ram 1500 Crew Cab Pickup Truck (A50323)
2014 Ram 1500 Crew...
2025 Kivel 48in Forks and Frame Skid Steer Attachment (A51691)
2025 Kivel 48in...
