10ft cutter
   / 10ft cutter #1
TXFord8n
Member
Ford 8n
What is the best two or three cutter brands out there right now in a 10ft size? Is the Deere house mower good? This will go on a JD 5065e.
   / 10ft cutter #2
I am not sure what the best two or three brands are. I can only speak for the one that I have. I have been running a Bush Hog brand 3210 offset for over two years now. If for some reason I had two buy another one, I would buy the same one again.
   / 10ft cutter #3
I really can't say for sure; guess it depends on what you want to spend, some commercial models made by Schulte will last most of us forever, but the price I've heard is pretty steep. We use Land Pride in our smaller mowers and we are on our third year with a Woods DS1260 10' model. I'm sure there are other makes like Bush Hog or others just as good, I just don't have any experience with them.
   / 10ft cutter #4
A 3210 would be my choice. Center pull, offset, trailing, semi-mount, fully mounted. However you want/need it.
   / 10ft cutter #5
i run a howse 120HD. it's a 3pt model but can be run semi-mount. good and hd, and was actually cheaper than the kodiak which had more crude looking welds.
laminated tail wheels and manual turnbuckle jacks on the rear wheel bar that can be converted with a kit to hyd.. or you can home-convert easilly too. came with a torque limiter on the main drive shaft. i've had -0- issues with mine. have used it since 2002. used to pull it behind a NH 7610s but now it lives on a ford 5000. it only gets a half season of mowing now as I added a batwing mower. I alternate mowings as I can get the corners better with the 10'er
   / 10ft cutter #6
I pull a 10' Mahindra (Kodiak) and have no complaints. Soundguy - the welds are not rough on mine .
idaho2
   / 10ft cutter #7
all i can say is back in 2002 I was looking for a 10' mower.
I looked at jd, howse, and kodiak, plus a couple others at auction.
the kodiak and howse were very close in price.. the howse had better looking welds.
might have been JUST that unit.. or kodiak might have better welds now 10 years in the future!
   / 10ft cutter #8
I got a 3209 that I picked up used. Mine is a 3pt hitch type, but basically works as a semi mount as well when I extend the hydraulic top link all the way. Been very pleased with it.
   / 10ft cutter #9
We have a Woods that has been the best piece of equipment we ever bought. The smoothness of the cut is almost as good as a finishing mower. We all fight to get to use it instead of the two 15 foot batwings even though it is only 10 feet wide. Very pleasing to use and to the eye when you get through. We pull it behind a 70 hp 3 cylinder New Holland and there is no tendency to bog down at all.
   / 10ft cutter #10
I like the Woods 10' cutter, although my neighbor likes his John Deere 10' cutter. I think that in addition to brand you need to look at how you will use the cutter, some brands offer a light, medium, and heavy duty 10' cutter, and they are available in pull type or 3 point hitch.
For my needs I am using a Woods medium duty 10 foot pull type and a Woods heavy duty 6 foot three point hitch cutter. The 10' cutter leaves a great cut and is a joy to use in open areas. The 6' cutter I can take anywhere and it can handle 3" material, it also makes a great counterweight.
2022 Polaris Ranger Utility Cart (A53421)
2022 Polaris...
10 FT Poly Bunk Feeder (A55218)
10 FT Poly Bunk...
CFG MH12RX Mini Excavator (A49461)
CFG MH12RX Mini...
2019 CATERPILLAR 745 OFF ROAD DUMP TRUCK (A52705)
2019 CATERPILLAR...
2016 FREIGHTLINER  CASCADIA (INOPERABLE) (A53843)
2016 FREIGHTLINER...
