Solution to frequent radiator plugging Grand L
   / Solution to frequent radiator plugging Grand L #1
MHarryE
Elite Member
Northeastern Minnesota
Kubota M7-171, M5-111, SVL75-2, RTV900XT & GR2120; CaseIH 1680 combine
Does anybody know how to keep their coolers from plugging quickly? Sunday afternoon I cut some grass and brush for the last time this year. I cleaned the radiator and air conditioner screens well before cutting. I worked about 3 hours and really didn't see dust in the air but the next morning when I checked the screens were over half covered, and a lot of trash made it past the screens so all 3 cores were plugged. I blew them all out, then went disking. I only had about 6 acres to cover, about 1 hour, but before I finished I noticed the temp gauge had crept up from 4 bars to 5 bars. Sure enough both screens and the cores were again filled half way up although I was disking ground that had Beene plowed, then disked three times before. I wish the screens would keep the cores clean but they don't appear to do much although it TSC easy to blow out the dirt which consists of plant material, not soil. When I clean it out I make sure to clean the stuff I blew out of the cores out of the space in front so it doesn't get sucked back in. Has anyone tried blocking the lower part of the grill to see if that helps? I thought of taking a saber saw to the hood and cutting a hole there, adding a screen to it, and blocking off all of the lower grill openings because they always seem to be cornered with plant material.
   / Solution to frequent radiator plugging Grand L #2
In very dusty conditions I have taken the grill out and covered it with pantyhose. It would filter out a lot of the dust and it was easier to clean than the factory screen. I would keep a small hand brush with me to sweep the pantyhoses off with.
   / Solution to frequent radiator plugging Grand L #3
I had the same problem while shredding. Had to go back to house to wash out radiator because of overheating....about every 3 hours.
I have not yet found an answer.....am short of pantyhose at the moment.....don't know, might help, it's an idea:anyone:
   / Solution to frequent radiator plugging Grand L #4
It's a problem with all of the newer style close-fin radiators. Back in the day the fins had more space between them and it wasn't as much of a problem, but the radiators were larger too. The efficiency of the fin design keeps the radiator size smaller (for those pretty sloping hoods, etc.) but they plug up quicker. Like you found out, in heavy conditions about 3 hours is all your going to get before you have to clean things out. I found out the hard way (at the 5 hour mark) and split a radiator seam wide open on my NH. It wasn't inexpensive to replace!
   / Solution to frequent radiator plugging Grand L #5
Dang, that would really leave you steamed!!:fiery:
Good explanation. Didn't realize fin spacing had changed over time. :confused3:
   / Solution to frequent radiator plugging Grand L #6
I have heard of reverse-flow fans. Has anyone tried that? I have not.
   / Solution to frequent radiator plugging Grand L #7
I would think a reverse flow fan will just plug the radiator or screen from the other side. If air can get to the radiator so can chaff, dirt and dust.
   / Solution to frequent radiator plugging Grand L #8
I think I'm going to go out and check mine after 4 hours of bush hogging.
Wider fin spacing is an answer but you are right, the radiator size has to increase. On combines we used 4 1/2 fins per inch to allow chaff to go through but the radiator was not in the operator's view. I believe my radiator is about 8 fins per inch, good for a lot of cooling in a small package but bad for trash clearance. The pantyhose is something I will try as soon as I get them off.
   / Solution to frequent radiator plugging Grand L #10
Mine would clog about every 1 hour bush hogging in this stuff. I would let it run up to 7 bars, then disconnect pto. By the time I got back to barn (little load on engine), bars would be down to 5 or 6. Clean screen, then go back at it again. Pusher fan is no good, would just clog back side where there is no screen. Pusher fan will also heat up faster because it will pick up heat off of engine and muffler. Philip.
CATERPILLAR 20" PIN ON BUCKET (A52707)
CATERPILLAR 20"...
2017 TROXEL 150 BBL ALUMINUM VACUUM TRAILER (A53843)
2017 TROXEL 150...
2019 CUMMINS CM20-1 PORTABLE SKID GENERATOR (A55745)
2019 CUMMINS...
2014 COMPTANK  ACID TRANSPORT TRAILER (A55745)
2014 COMPTANK...
2015 Toro Multi Pro 1750 175 Gallon Turf Sprayer Cart (A55851)
2015 Toro Multi...
