10ft cutter
   / 10ft cutter
The tractor I am going to buy is Deere, but made in India. NH was Turkish and the Kubota was in Georgia, but it was too light. I have done a little research and I think the Modern Predator is the route I will take.
   / 10ft cutter #22
Thread hijack!! What kind of batwing you going to get for your 7040 there Foreman?
For a top notch ten footer look at the Shulte line out of Canada. They are owned by the Alamo group that also owns Bushhog brand and Rhino. We have a old Bushhog that has just run and run without any trouble they knew how to build them back 35 years ago!
   / 10ft cutter #24
TXFord8n,
First of all, I hope you have a bigger tractor in mind! :D (sorry, I couldn't help myself)
About 20 years ago, I was shopping for a 10' myself. Bought a Hardee pull-type. It's a beast. It spent it's first 15 years (or so) behind a 100 hp tractor. (JD 4020, then a NH 7610S) It will basically digest anything that the tractor will run over. .
when i got my nh7610s in 02, that was the first size of mower i had on her, a 10', 3pt hd howse. as you said. with a 10' mower and high hp.. it will mow anything you can drag it over.
   / 10ft cutter #25
Here's the one I like, but my tractor won't pull it... time for a bigger tractor!!
http://modernusa.com/images/10offflex-pop.pdf
I hope you have flat ground with no humps or terraces because that mower will scalp going over them where the blades overlap because it's so long front to rear. I do have terraces and I run a JD HX-10 flat deck and it doesn't scalp too bad but I still have to raise it sometimes as I'm going over. Plus I don't see the cost effectiveness of buying a 10 foot bat wing versus a 10 foot flat deck mower that will cost much less. Another thing, don't fall for the mfr's minimum hp specs of 50 hp. You're going to need 90-100 hp to cut thick grass well with a 10 foot mower.
   / 10ft cutter #26
i'v never had a scalping problem with my 15' batwing, on rare occasion, i have had a side to side problem on a 10' fixed deck though..a 15' batwing should be about as deep as that 10' offset flex.
   / 10ft cutter #27
I'll second the higher Horsepower, I have 83 hp to run a MX10 John deere and you can tell its back there when the grass gets as tall as the tires. The only time I really notice it bogging down is when it scalps the ground. The good thing about that though is the next time there is alot less dirt to cut through! I guess i should be fair, IIRC i have 69 pto hp. TheMX10 is a great counter weight and I refuse to mow with it without the loader or my suitcase weights loading the front end down! I think it tips the scales at somewhere near 1700lbs? It sure is nice though taking a ten foot swath of grass down instead of 8!!
   / 10ft cutter #28
that hd howse 10' is around 2400#
My 7610s has a full populated front weight bracket.
My ford 5000 totes the mower now.. t has a full set of pillow weights.. and then I added 2 fat suitcase plates to either side of the front bolster to keep the front down.
the 7610s has about 89 pto hp and the 5000 has 67 pto hp.
soundguy
2017 CATERPILLAR D6T LGP HI TRACK CRAWLER DOZER (A52705)
2017 CATERPILLAR...
2021 Doyle 8 Ton Trailer Tender (A53472)
2021 Doyle 8 Ton...
2017 Makita HM1307CB 35lb Demolition Hammer (A52377)
2017 Makita...
2015 MACK ELITE LEU633 GARBAGE TRUCK (A51406)
2015 MACK ELITE...
2007 CHEVROLET SILVERADO TRUCK (A54756)
2007 CHEVROLET...
2019 Energreen EVO 40 Robotic Tracked Flail Mower (A55218)
2019 Energreen EVO...
