hits 5 or 10 times and stops.
   / hits 5 or 10 times and stops. #1
ken12
lebanon, tn
L185
rebuilt engine. was sitting in box in parts. I didin't take apart so not sure if it all went back together correcly. however it starts but won't stay running. is timing correct? not sure if i got all the shims that came out of it. engine is L185 diesel.
   / hits 5 or 10 times and stops. #2
Well What kind of engine is it?
   / hits 5 or 10 times and stops. #3
not sure what you have for an engine.. however from a general view.. if an engine starts and runs, timing is at least close, as is compression, valve setup, and ignition or points.
at point of stall, if it uses spark/battery ignition ( gasser).. check to see if it still has spark on turn over.. if yes.. go to fuel.
most start/run/fast stall is fuel.
ie.. float needle or seat is stuck or clogged, and fuel just dribbles into bowl.. engine will start then starves off fast...
post back some actual specific details to get some actual specific advice.
engine is L185 diesel. 20 horse.
   / hits 5 or 10 times and stops. #5
if it starts, injection timing and valves and comp are good.
if it dies.. it's fuel.
a diesel engie is pretty much an air pump.
got an electric fuel shutoff? check that... otherwise.. make sure fuel gets to the IP..
20X30 ALL STEEL CARPORT (A53843)
20X30 ALL STEEL...
2016 Big Tex 14ft. T/A Hydraulic Dump Trailer (A50322)
2016 Big Tex 14ft...
1998 CATERPILLAR 120H MOTORGRADER (A51406)
1998 CATERPILLAR...
2015 International 4400 SBA Gap Vac Truck (A53117)
2015 International...
2008 Isuzu NPR-HD Landscape Dump Truck (A53422)
2008 Isuzu NPR-HD...
