My Ferguson Continental 135 engine cant find where to hook up the oil gauge line
   / My Ferguson Continental 135 engine cant find where to hook up the oil gauge line #1
Knifer
Winter Haven
Massey,JD 2010, International W6. '42 case
any Ideas where the oil port is?
   / My Ferguson Continental 135 engine cant find where to hook up the oil gauge line #2
I happen to have a picture I took while working on mine.
The oil gauge line connection point is located just to the right of your battery negative post connection point to the frame on the right side of the tractor. Just to the left of the oil filter.
You should use a line wrench when loosening or tightening it. I would put a bit of teflon tape on it upon final assembly. When you hookup to the gauge you will need to bleed the line at the gauge while engine is running till you see oil comming from the line then tighten securely. If you don't. Your gauge will either not work right or be inaccurate. -robert
thaanks
100 GAL FUEL TANK W/PUMP TOOLBOX COMBO (A53843)
100 GAL FUEL TANK...
2016 Chevrolet Tahoe SUV (A52377)
2016 Chevrolet...
JOHN DEERE XUV835M (A53084)
JOHN DEERE XUV835M...
2016 Isuzu NPR Cab and Chassis Truck (A51692)
2016 Isuzu NPR Cab...
2023 International MV607 Ambulance (A51692)
2023 International...
1999 Yale 3,500lb Electric Forklift (A51691)
1999 Yale 3,500lb...
