Snow Differential lock broken on Foton FT404-2009
   / Differential lock broken on Foton FT404-2009 #1
traktorz
Scandinavia
Foton FT404 (C490BT1)
Unfortunately, we've not been following the instructions on using this feature, with the result it's now broken. The evidence was visible when replacing the oil from the gear box last year, pieces of metal which we presume comes from the "differential lock assembly".
Last winter we put on snow chains on the rear tires, I suppose we'll do that this winter as well.
I guess it's a pretty ambitious task to replace this assembly? Does any forum reader here have experience on the task and expected time it takes to repair the differential lock on a Chinese tractor or any others?
   / Differential lock broken on Foton FT404-2009 #2
Yes, it will be time-consuming, but to the best of my knowledge you don't have to split the tractor. Pretty sure it involves removing the operator seat, the hydraulic sump, at least one rear wheel, possibly even an axle housing. Going through from the top means you'll likely have to move the PTO drivetrain out of the way as well. I have access to the manuals, but they're about 40 miles away. This is the best I can do for now.
//greg//
..., at least one rear wheel, possibly even an axle housing.
Does it matter which rear wheel to remove? Is there a preferred side to work from?
   / Differential lock broken on Foton FT404-2009 #4
I wish I could answer that, but I simply don't have the manuals available to be any more definitive.
//greg//
2008 Ford Crown Victoria Sedan (A51694)
2008 Ford Crown...
2018 Infiniti QX60 AWD SUV (A51694)
2018 Infiniti QX60...
2025 IR IRMC 8D UNUSED Massage Chair (A53117)
2025 IR IRMC 8D...
2021 Harley-Davidson FLHP Police Electra Glide Motorcycle (A51694)
2021...
2016 Dodge Charger SRT Hellcat Sedan (A53424)
2016 Dodge Charger...
2017 Freightliner M2 Cab & Chassis (A53117)
2017 Freightliner...
