Oil Filter used for Hydraulic filter?
   / Oil Filter used for Hydraulic filter? #1
Noodlez914
New York
John Deere 1023e
Hey everyone.
Although this question is not Tractor related, it is still hydraulic related. Decided to give my log splitter an oil change today as well as change the hydraulic filter. Ran to the local NAPA, showed them the filter, they cross referenced it and handed me the one that will work. Got home and realized it was an oil filter. Called them, they assured me it matched the same specs as the filter I showed them. I ended up putting the newly purchased oil filter on but my question is....
Should I be concerned about keeping this on? Is there a difference between Hydraulic filters and oil filters. I would assume so since they sell both but I will I get by with this one until next season?
   / Oil Filter used for Hydraulic filter? #2
What is the micron rating of both? I would go to a hydraulic shop and get the proper filter. Typical NAPA.
They are both 10 micron.
   / Oil Filter used for Hydraulic filter? #5
hyd fluid is oil.... both are oil filters.. :)
i have also seen crossover applications like that...
Actually did a little searching around last night online. Appears Hydraulic fluid flows through the filter with a lot more pressure then engine oil does. Hmmm wonder if a hydraulic filter is rated to withstand more pressure.
   / Oil Filter used for Hydraulic filter? #8
The filter is on the return side.
2013 FREIGHTLINER EXT CAB SERVICE TRUCK (A51406)
2013 FREIGHTLINER...
2000 PETERBILT 357 6X6 DAY CAB ROAD TRACTOR (A51406)
2000 PETERBILT 357...
84'' skid steer bucket (A53421)
84'' skid steer...
2008 KOMATSU PC200LC-8 EXCAVATOR (A52706)
2008 KOMATSU...
4X8 PUMP (A53843)
4X8 PUMP (A53843)
2018 CATERPILLAR 815K LANDFILL COMPACTOR (A52705)
2018 CATERPILLAR...
