FEL Loader bucket repair metal?
   / FEL Loader bucket repair metal? #1
Claytonfarms
Member
Harford, Maryland
Ford 550 TLB
Recently purchased a Ford loader, the FEL bucket edge is very worn. I have a few snow plow cutting edges 6" x 1/2" x 8'. Could I use this? I got a few of them cheap a couple of years ago and never used them. There is approx 3 inches of the old edge left on the bucket. I was going to weld the plow edge to bottom of bucket, weld the back and run a bead down the front top side of the old bucket edge. Maybe some plug welds thru the bolt holes in the plow blade.
The only thing I know about the plow edges is that it is the correct length and it is sold as high carbon steel. I have used one on a snowplow and it seems to last.
If the snowplow edge is not good, does anyone have a source for inexpensive bolt on or weld on cutting edges?
I am mostly only using the loader for dirt and snow moving.
Thanks
   / FEL Loader bucket repair metal? #2
if you can get it fastened on than call it good... I'm using a unknown blade for a improved edge on my box blade...
   / FEL Loader bucket repair metal? #3
That will work, esp if it already has a bevel on one edge. This "plow steel", a hot-rolled tough
alloy, is very pricey at the tractor dealer. You did well to find some, reasonably priced. I found
some at a steel disti/recycler.
When you weld, space your "stitches" out to avoid warping the blade.
   / FEL Loader bucket repair metal? #4
Been there and done that a few times, it'll work fine. As Dfkrug suggested space your stitches and take your time, it WILL warp otherwise.
2020 HINO 195 CAB AND CHASSIS (A51222)
2020 HINO 195 CAB...
2021 KUBOTA SVL 97-2 SKID STEER (A51242)
2021 KUBOTA SVL...
Fire Place Mantel (A49462)
Fire Place Mantel...
LOT LOCATIONS (A51219)
Komatsu D39PX-24 Crawler Tractor Dozer (A49346)
Komatsu D39PX-24...
2021 GMC SIERRA CREW CAB TRUCK (A51406)
2021 GMC SIERRA...
