Trailer Emergency Brake Incident
   / Trailer Emergency Brake Incident #1
homeputter
Glendale, AZ
I was cruising along at 65mph towing my BX25 on my 18' trailer when I saw a piece of tire retread in the road. It was not very big so I did not attempt to avoid it. As soon as I drove over it, I heard tires squealing and saw lots of blue smoke in my rear view mirror. I pulled over and saw the plug for the emergency trailer brakes had been yanked out. Apparently, the emergency brake cable was hanging low enough that the retread piece in the road was able to catch it and pull it out. Fortunately, the trailer/truck stopped smoothly and no damage was done, but it scared me for a few minutes
I think I will disable the emergency cable as I think it is much more likely to be caught on something in the road then my trailer becoming unattached and needing to be stopped. Has this happened to anyone else? You might want to check how close your emergency cable is hanging to the road.
   / Trailer Emergency Brake Incident #2
Dont do it. Find a way to route it so that the cable wont snag. If you get pulled over (or are in an accident) you could get a ticket or your insurance company may refuse to cover you.
Aaron Z
   / Trailer Emergency Brake Incident #3
Good tip. Definitely route the cable safely. But don't disable it, especially if you live in a state that requires it. The worst-case scenario is that your trailer comes decoupled and then kills somebody, and if that happens and you've disabled a safety feature, you are going down.
   / Trailer Emergency Brake Incident #4
I cannot believe I just read this statement!!! If you cannot figure out lacing the cable through your safety chains will keep this from happening then you need to some reading on safety towing equipment. With this mentality you have no business operating or moving equipment as you are a risk to everyone and should not be on the road.
Read down a few lines about the U-Haul trailer breaking loose.
David Kb7uns
   / Trailer Emergency Brake Incident #5
Doing away with the cable is foolish. Its like saying I am not going to wear my seatbelt because I may burn up if I am trapped.
Chances are it will never happen to you again. Just leave the cable.
Chris
   / Trailer Emergency Brake Incident #6
David Kb7uns
Glad you mentioned disabling the emergency cable.
Lacing it through the safety chain seems like it should work.
Maybe doing some searches on the internet will provide more information about towing equipment. I've seen links offered up on TBN that offer information on securing loads and such. Please don't disable the safety equipment on your towing rig, for your sake and others on the road.
   / Trailer Emergency Brake Incident #7
actually it would be harder for cable to do its job if interlaced in safety chains. I would just simply modify your setup of your breakaway setup. It sounds like cable is simply too long? or do you need a new mount point on the tow vehicle for breakaway cable? or move the breakaway module further back on A frame ? Without pics and not seeing it- its hard to tell if it just a simple one time thing, or improper setup.
I would more likely to chalk it up to a one time thing and just walk away happy it worked the way it should have been.
   / Trailer Emergency Brake Incident #8
I can't believe I read this either?
You should be made to sell your trailer and banned from ever owning one again with though process that work like that!?!?!
use yer brain and route the wire so that the various road debris that you don't dodge don't snatch out the breakaway cable...
sheesh....
   / Trailer Emergency Brake Incident #9
I wondered the same thing. If the chain stretched tight but there was still some slack in the cable, wouldn't it defeat the purpose?
   / Trailer Emergency Brake Incident #10
As others have said, you really just need to set up the emergency cable so that it's not hanging low. I put a loop in mine, and hang it from the lock-pin that goes through the coupler latch.
2011 Superior Trailers of Georgia Trailer, VIN # 4M8FZ1629BD000279 (A51572)
2011 Superior...
2012 FORD F-550 SUPER DUTY XLT SERVICE TRUCK (A51406)
2012 FORD F-550...
UNUSED CFG INDUSTRIAL MX12RX EXCAVATOR (A51247)
UNUSED CFG...
2012 Ram 3500 4x4 Dump Truck, VIN # 3C7WDTAL9CG134341 (A51572)
2012 Ram 3500 4x4...
Mccormick Hammer Mill (A51573)
Mccormick Hammer...
