MX 5 rotary cutter broken main shaft
   / MX 5 rotary cutter broken main shaft #1
cowboy camp
Ogdensburg, NY
John Deere 3320
Running my JD mx5 rotary cutter yesterday the bottom disc that holds the blades fell off, apparently the main shaft sheared. I am a mechanical clutz, has anyboby replaced the shaft ?
   / MX 5 rotary cutter broken main shaft #2
Thre is in Attachment forum a long listing of MX5 or 6 problems with the shaft breaking.
Mine the price was 375 or close to this then seals and gears amounted to 775 to rebuild the box. or 1200 to have J.D. do the rebuilding. Now if built after Nov.2010 there may be a warrenty.
Took to machine shop to see if could be rewelded the man said no.
let us know what you decide to do.
ken
   / MX 5 rotary cutter broken main shaft #3
Yeah, do a search. You will find several fellow members here in the same boat. Unfortunately, JD is not standing behind most of the breaks, even though it is an obvious problem.
   / MX 5 rotary cutter broken main shaft #4
In the vein of Microsoft, that's not a flaw, its a feature. It keeps you from mowing too much.
   / MX 5 rotary cutter broken main shaft #5
Welcome to TBN :)
I moved your thread to the Attachments forum.
   / MX 5 rotary cutter broken main shaft #6
While not "common", it's one of the things people seem to complain about with the JD cutter.
   / MX 5 rotary cutter broken main shaft #7
True, but when you own one you think about it every time you hook it up to mow.
   / MX 5 rotary cutter broken main shaft #8
I get several call a week on the MX output shafts. It covers from the MX5 to the MX10. I can recommend several compatible gearboxes which can be fitted with a minimum of modification.
The gearbox will fit the 15 spline hub on the stump jumper w/a slight mod and that can save a lot of dollars.
The MX decks are great and it is a shame to scrape it when you can replace the gearbox for less than half what it costs for the Deere fix.
Dawson
dawson@tractors-equipment.com
2012 INTERNATIONAL PROSTAR +122 EAGLE 6X4 ROAD TRA (A51247)
2012 INTERNATIONAL...
2006 CATERPILLAR 330DL EXCAVATOR (A51246)
2006 CATERPILLAR...
UNUSED X-STAR 20' X 101" LOADING RAMP (A51247)
UNUSED X-STAR 20'...
2011 BOMAG BW211 D-40 SMOOTH DRUM ROLLER (A51246)
2011 BOMAG BW211...
