Clearing brush and saplings in tight areas.
   / Clearing brush and saplings in tight areas. #1
Pa Pa Jack
Hodges, SC
Mahindra 3016
   / Clearing brush and saplings in tight areas. #2
Interesting. Seems to work good in the video. I wonder if each tree has to be isolated. Or would it still work if they were bunched together ?
   / Clearing brush and saplings in tight areas. #3
Looks like it works good on flatish smooth ground, especially on soft wood. Not much good on the maple and ironwood alongside our trails up here, you could never get up enough speed on the rough ground.
   / Clearing brush and saplings in tight areas. #4
If the trees are smaller than the 4" max, I believe it would work. Once you get a trail thru it just keep widening it to where the tractor/bushhog could get in there to finish it up!
Just my :2cents: worth
   / Clearing brush and saplings in tight areas. #5
Looks like it works but curious how much stress is put on the vehicle, especially if it doesn't cut the tree on the first try. Probably would be a sudden stop for the 4 wheeler but the driver would continue into the tree.
   / Clearing brush and saplings in tight areas. #6
That shear is a lawsuit waiting to happen. If it doesn't tear up the frame of the ATV quickly enough, it will throw you over the handlebars as soon as you hit one that the shear can't handle.
   / Clearing brush and saplings in tight areas. #7
That's about what I was thinking. I'd bush hog most of those.
   / Clearing brush and saplings in tight areas. #8
Read the fine print: available from April 1 2013 ........And just where are the trees?
:eek: Just imagine the shock/stress loads being placed on the ATV, & the rider when it all comes to a screaming halt when headbutts a 40' sapling ........
PaPaJack use your FEL to push those saplings from high up & invest in a grapple or a root raked to clear the debris.....even chaining would be better than this "Tree Shear"..................
   / Clearing brush and saplings in tight areas. #9
Interesting concept but the video shows saplings/brushes that could be easier cut down with a bush hog...
For tight places that are inaccessible with a hog I would prefer a FEL dig out operation to completely remove the stump...
I would be concerned with the stress placed on the ATV...
I don't like the thought of running up at those speeds to a sapling like that...
Looks like a good way to tear up your ATV or worse have an accident...
   / Clearing brush and saplings in tight areas. #10
Certainly it looks dangerous, but with small stuff only I see it working FAST.
If you put an idiot or a kid behind the wheel and if there are larger trees
that need to come down you can bet there is going to be a problem...
BESTWAY LOT NUMBER 40 (A53084)
BESTWAY LOT NUMBER...
2017 Yale GLC050VX 3,500 lb LPG Forklift - Powershift, Aux Hydraulics (A52748)
2017 Yale GLC050VX...
EZGO GOLF CART (A50323)
EZGO GOLF CART...
TOW BEHIND FINISH MOWER (A50324)
TOW BEHIND FINISH...
WESSEX 1.5T LOT NUMBER 172 (A53084)
WESSEX 1.5T LOT...
(1) 14ft Tarter Gate (A51573)
(1) 14ft Tarter...
