1950 case tractor
   / 1950 case tractor #1
brian1950
Milwaukee, wi
1950 case tractor
Hi
I have a 1950 case VAI tractor. I used to own a 1931 ford model a, which required non detergent 30 weight oil. I have 6 quarts left over. Can I use this in my tractor?
Brian
   / 1950 case tractor #2
brian1950 said:
Hi
Brian
I would not. ND will just increase wear. Give it away or use it in a gear box calling for 30W or as bar oil for your chain saw.
Chris
   / 1950 case tractor #3
I use 30w non detergent in my Case Sc. Thats what the manual called for.
   / 1950 case tractor #4
we used to hang people and burn them for witchcraft back before we knew any better either.
there are plenty of better oils out there.
if a machine has an oil filter.. it will benefit from an oil with a detergent. this isn't 1927 :(
   / 1950 case tractor #5
Well the SC's like mine don't have a filter. They have a screen over the pick up in the oil pan and that's all. The holes in it are about 1/8inch in size.
   / 1950 case tractor #6
for that.. I'd say no detergent oil and not feel too bad about it.
That vai should be filtered though right?
2004 CAT 953C Crawler Loader (A47477)
2004 CAT 953C...
John Deere (A50322)
John Deere (A50322)
Scag Mower (A50324)
Scag Mower (A50324)
2022 Ford F-250 XL 4x4 Ext. Cab Pickup Truck (A52377)
2022 Ford F-250 XL...
2005 CATERPILLAR 12H MOTOR GRADER (A51406)
2005 CATERPILLAR...
2016 RAM 5500 Bucket Truck - Cummins Diesel - Auto Trans - 4X4 - Altec AT41M Boom (A55218)
2016 RAM 5500...
