PTO Generator Wet Stack?
   / PTO Generator Wet Stack? #1
avc8130
Northern, NJ
Kubota L45
Are there any concerns with wet-stacking?
If the tractor is singing along at ~2550 rpm to maintain 540rpm at the PTO to maintain 60hz...this would be a BAD situation on a standalone diesel genset unless the generator is loaded at least 40% of capacity.
Is this "problem" non-existent on the tractor?
ac
   / PTO Generator Wet Stack? #2
ac
You have a load sensing generator?
As long as the tractor has coolant, engine oil,
fuel and an intact V belt for the water pump it
will run until it is run out of fuel or the squirrels
in the neigborhood steal it for a joy ride and crash it.
   / PTO Generator Wet Stack? #4
I think you just answered your own question. if a tractor NEEDS to be ~2550 rpm to maintain 540 rpm at the PTO then its fine for the tractor. For the standalone genny - I am sure its designed differently. Just like MY BX tractor. It needs to be at high RPMS to be at rated pto that is considered screaming to others who are used to larger engines that purrs at low rpms.
   / PTO Generator Wet Stack? #5
If I understand the "wet stacking" issue correctly, the concern is engine deposits from repetitive cycles that don't load the engine and warm it to temperature. For a tractor mounted generator I would assume you use the tractor for other task. During those work cycles the engine should warm sufficiently to remove any deposits.
Sort of. The main concern is operating the engine at a high rpm (2550 in this case) to get the required 60hz, WITHOUT a load. Generally speaking, there will be very little load on the engine unless the generator is producing more than 40% of its rated output. For a 30hp PTO, that would be a 15kw generator with a 6kw load. This would generally only be the case when well pumps, fridges, and other large loads are actually DRAWING power.
ac
   / PTO Generator Wet Stack? #7
i think the generators the article refers to are air cooled.
Your tractor likly has a thermostat that controls the engine temp.
   / PTO Generator Wet Stack? #8
Actually, this is less of a problem with aircooled diesels as they run hotter.
IMO, if you are using it as a tractor regularly, this shouldn't be an issue. It more of an issue when gensets sit (a lot), don't get fully warmed up in testing and then are lightly loaded.
Aaron Z
   / PTO Generator Wet Stack? #9
I hook up my 50kw Winpower just to run a 110v hedge trimmer out in front. Its been fine for 20 years. No I'm not worried.
Here is a sample Owners manual for these jobs. Note the comments about split-phase motors and starting current.
It's not about a problem on the GENERATOR side, it's about whether it can damage the tractor engine.
Hooking up a 15kw pto genset, and running the tractor for 10 straight days during a power outage, only drawing a few kw.
That is my concern.
ac
CASE TV450B SKID STEER (A52709)
CASE TV450B SKID...
2021 UTILITY VS2DX 53FT DRY VAN (A59575)
2021 UTILITY VS2DX...
2001 Freightliner MB55 Bus (A56858)
2001 Freightliner...
SKIDDED FRAC TANK (A58214)
SKIDDED FRAC TANK...
1985 FREIGHTLINER DUMP TRUCK (A58214)
1985 FREIGHTLINER...
2014 BIG TEX (A58216)
