JD 4120 antifreeze leak
   / JD 4120 antifreeze leak #1
D4120
IN
JD4120
Just took my 4120 to shop for coolant leak. After reading some posts, this appears it might be a leaking timing cover gasket. Just wondering if anyone has had luck getting JD to cover the cost since it's a known issue with the gasket on the 4120. It's an '06 with 650hrs. I know it's out of warranty and I may be forced to eat it but I'm gonna try. Any suggestions??
   / JD 4120 antifreeze leak #2
Unless there was some kind of recall, you will have to cover it. You are just too far out of warranty.
   / JD 4120 antifreeze leak #3
Where did you see that this is a known issue? I have a 4720 and will have to watch out for it. No problems yet.
   / JD 4120 antifreeze leak #4
Apparently, if atleast 1 other person posts about it, it may be a known issue.
   / JD 4120 antifreeze leak #5
I do believe there is a thread going about a 4x20 with similar issue.
I just googled the issue and it returned a few different sites and comments from others with the same problem. I've not heard for sure from the shop but I'm afraid this may be the case with my 4120. I couldn't pinpoint the leak, just that it was originating from above the water pump somewhere and running down the face of the block. Sounds like a simple fix......wrong, look at this image posted by another. If there is a thread going, where would I find it?
http://www.********************.com/equimages/5190988.jpg
   / JD 4120 antifreeze leak #8
Put some spaces between the words in the link, we can put it back together.
If you google antifreeze leak 4120, click on the 3rd link it returns and you'll see a picture someone has posted of their 4120, less the ENTIRE front end. ****, that seems like a lot of work to repair a coolant leak......just saying. Thanks guys for the replies.
   / JD 4120 antifreeze leak #10
I would ask for sure, cannot hurt. You getting a quote on the repair cost?
2003 Big Tex 10PI 16ft. T/A Pipe Top Utility Trailer (A52377)
2003 Big Tex 10PI...
1993 International 4900 Flat Dump Truck, VIN # 1HTSDPNM9PH489370 (A51572)
1993 International...
2004 IC Corporation 3000IC School Bus (A51692)
2004 IC...
2024 JOHN DEERE CP 770 LOT NUMBER 22 (A53084)
2024 JOHN DEERE CP...
2014 Nissan Juke SUV (A51694)
2014 Nissan Juke...
2020 GENIE TZ-34/20 TOWABLE MANLIFT (A51242)
2020 GENIE...
