best place to buy a rear remote kit -new holland
   / best place to buy a rear remote kit -new holland #1
hotchkiss
Gold Member
Ohio
JD 6330, JD 5055e, Ford 4000,
I am going to add a second rear remote to a New Holland TN-95A. Where is a good place to order the kit on line?
   / best place to buy a rear remote kit -new holland #4
A stacked valved will allow you to select the options you need on each spool.
The cost on a valve from Surplus or Baileys will be a lot less.
If you have the ability, you can come up with the parts to install, say a 3 or 4 spool remote valve and save money, and learn something also.
Some of your options may include things like float, detents, motor spool, etc.
Stacked valve will also allow you to add more spools in the future if needed.
Something like this.
Surplus Center - 4 SPOOL SV VALVE OPEN CENTER W/POWER BEYOND
Check with NH to see if they have a remote kit.
UNUSED Under Mount Stainless Steel Sink & Faucet (A53117)
UNUSED Under Mount...
UNUSED 20PCS Industrial Polyester Lifting Straps (A53117)
UNUSED 20PCS...
2006 TerraGator 8104 (A55301)
2006 TerraGator...
2015 Ford Taurus SE Sedan (A54815)
2015 Ford Taurus...
2025 12V Diesel Pump and Hose with Meter (A50324)
2025 12V Diesel...
