Buying a MF 135
   / Buying a MF 135 #1
murphy1244
Super Star Member
Ohio
Kubota 1120 RTV Kioti DK-40, MF-135, Ventrac 4500Y
Well I have a possible deal on a 135 Diesel, power steering 2 stage clutch and 5000 hours for 2575.00. Can be seen a tractor house at sterling Farm. What do you guys think and what should I check on it before purchase. Does need a battery.
   / Buying a MF 135 #2
Check to be sure there is no oil in the antifreeze or antifreeze in the oil. Doesn't smoke when running. How well the brakes work. Drive it and with the clutch engaged stomp on the brakes like you never have before and see if the engine lugs down or the clutch slips. Check play in steering, play in clutch pedal...
   / Buying a MF 135
What is it supposed to do when I mash on the brakes? Thanks for replying.
   / Buying a MF 135 #5
It's supposed to die....if it stays running with the rears locked for any amount of time, the clutch is slipping...you can do the same test on a clutch by taking off in 6th gear...it better choke out rather than slowing pick up and go. BobG in VA
   / Buying a MF 135 #6
Ya beet me too it.
   / Buying a MF 135
Bob, Are you supposed to shift this tractor like you would a car or should all gears be started from a dead stop. This would be my first gear tractor.
   / Buying a MF 135 #8
I'm not Bob but the gears in these tractors are square cut gears and are non synchronized. Meaning you have to stop to shift or you grind the gears. If it is worn or you know the tractor well you can shift on the move. In your case shift while stopped.
   / Buying a MF 135
Thanks Mike, I'm learning.
   / Buying a MF 135
bump!
2017 DRAGON PRODUCTS 130BBL VACUUM TRAILER (A53843)
2017 DRAGON...
2015 Ford Focus Hatchback (A51694)
2015 Ford Focus...
Skil 5 speed Small Drill press (A53117)
Skil 5 speed Small...
2015 Ford F-450 Cab and Chassis Truck (A51692)
2015 Ford F-450...
2004 Ford F-250 4x4 Service Truck with Liftgate (A53422)
2004 Ford F-250...
