Tow Bar
   / Tow Bar #1
Bubbit
Menlo Georgia
Kubota M7040 with loader
I run a Kubota M7040 on my place. Looking for ideas for tow bar attachments to pull stumps and logs with. Something to hook a chain too. Can I just attach a d-ring or are there other attachments to consider? Is there a good on line store to shop for these things
   / Tow Bar #2
There are lots of ways. A shackle or tractor hook on the draw bar. I also use a cross draw bar and a tractor hook so I can lift for easier dragging. It is about the simplest thing. There are also lots of stuff you can buy or make as I am sure you will see.
Follow the main rules: Be careful. Go slow. Pay attention. Don't let your front end come off the ground.
   / Tow Bar #3
To pull logs, I use a skidder plate on the three point hitch that lets me lift the butt of the log off the ground with a choker chain. It was about $150 on eBay. For pulling stuff that is more "immovable" like a stump, I'd only want to pull from the tractor drawbar, which will be a lot safer.
   / Tow Bar #4
I second this method. Good way to go. Safety is also a concern in method.
   / Tow Bar #5
I think chaining a tractor to a stump is a good way to make sure it doesn't run off on you.
   / Tow Bar #6
I would just pull a log of the tractor drawbar a 3PH draw bar like Gordon pictured. You have to watch with pulling of the 3PH the higher it is the easier the front will come of the ground. For pulling a stump I would pull of the tractor draw bar but you probably won't be able to pull a very big one unless the tree has shallow roots.
If you want to get fancy for pulling logs you can get a grapple or a , skidding plate.
   / Tow Bar #7
I have to ask where you found the choker hooks ?:thumbsup:
   / Tow Bar #8
As for me, I got mine at a local hardware store. I think the feed store also has them.
   / Tow Bar #9
Baileys sells choker hooks, as well as Northern Tool (online, not sure about stores). Usually $10-15. You can also use a large open chain hook, which will cost a lot less and be more commonly found.
   / Tow Bar
Thanks Tractor Supply Store here I come!
2013 International Day Cab Semi (A50120)
2013 International...
12in Backhoe Bucket (A52748)
12in Backhoe...
KJ 45'x25' Metal Garage (A50121)
KJ 45'x25' Metal...
2006 TerraGator 8104 (A52748)
2006 TerraGator...
2000 John Deere 7810 Tractor W/Loader (RIDE AND DRIVE) (A50774)
2000 John Deere...
2013 Chevrolet Caprice Sedan (A51694)
2013 Chevrolet...
