looking for 101 off the wall uses for my kubota
   / looking for 101 off the wall uses for my kubota #51
in my B2620 in the FEL about 30 gallons of water and 5 gallons on tomato juice, spritz of vineger.....
used to wash one of my Rottis after she had a run in with a skunk last month
   / looking for 101 off the wall uses for my kubota #52
   / looking for 101 off the wall uses for my kubota #54
How'd this recipe work for you? I've used, unfortunately a few times :grumpy:, Dawn liquid soap + hydrogen peroxide + baking soda mixed to a paste consistency which works really well, unless the dawg already got into the house!
   / looking for 101 off the wall uses for my kubota #55
I use my fel to load my boat, to help put stuff on the car roof, as a kayak carrier and to bring in the groceries. Also have used it to put an outboard motor on it so i can lower it into the pool to test and run the motor.
   / looking for 101 off the wall uses for my kubota #56
Thats a compleat 460 ford hanging off my BX.:D
   / looking for 101 off the wall uses for my kubota #57
<img src="http://www.tractorbynet.com/forums/attachment.php?attachmentid=291419"/>
Thats probably 750lbs. :DWhat did you have on the back to keep it down?
   / looking for 101 off the wall uses for my kubota #58
I have a 3 point carry all (looks like fork pallets) and a small wood pallet. I strap my chipper shredder to the pallet and go along the property chipping and shredding stuff. Now I don't have to try and drag it by hand and I can lower and raise it so my back won't hurt so bad bending over to load the chipper shredder.
   / looking for 101 off the wall uses for my kubota #59
That might be a good idea to have several different items permanently mounted to skids like that. The chipper, a generator, etc. Then they can be easily picked up and moved where ever needed.
   / looking for 101 off the wall uses for my kubota #60
worked so / so.
after 6 weeks she still carrys a bit of that "oh so skunky" stink in her dewlap.
Takeuchi Skid Steer (A49461)
Takeuchi Skid...
(10) 20' Continuous Fencing Panels (A50515)
(10) 20'...
1 Oliver Front Weight (A50515)
1 Oliver Front...
2016 CIMC 40FT CONTAINER CHASSIS (A52141)
2016 CIMC 40FT...
JLG 1932R 19FT Electric Scissor Lift (A50322)
JLG 1932R 19FT...
2011 PETERBILT 367 TRI-DRIVE WITH TAG (A52472)
2011 PETERBILT 367...
