New to the Green
   / New to the Green #11
Thanks MtnViewRanch and Murphy1244. I already have the JD TNT but was just curious how it compared to the recommended sizes from other suppliers. I don't know the inside dia of the JD cylinders but the OD is 3 3/4" and the shafts are a little over 1 1/2" at 1.6". Sounds like mine are way overkill for my size tractor but it was the JD recommended kit for the 3320.
I'm pretty sure that JD uses the same diameters on all of their kits, no mater what size the tractor is. Any chance of some pictures of you "TnT"? :cool:
   / New to the Green #12
Here you go:
   / New to the Green #13
Eric, GREAT pictures. Thank you very much. Always good to see what I'm up against. ;)
   / New to the Green #14
They may also fit a larger tractor.
2015 Ford Taurus Sedan (A48082)
2015 Ford Taurus...
1999 Ford F-150 Pickup Truck (A48081)
1999 Ford F-150...
Rear Wheel Weights (set of 2) (A49251)
Rear Wheel Weights...
Vicon CM165 5ft. 3pt Disc Mower (A49339)
Vicon CM165 5ft...
2013 Chevrolet Impala Sedan (A48082)
2013 Chevrolet...
2015 FREIGHTLINER 108SD WITH ELLIOT H110 CRANE/MANLIFT (A48992)
2015 FREIGHTLINER...
