MF 135 DO THE HEADLIGHTS HAVE A LOW AND HIGH BEAM?
   / MF 135 DO THE HEADLIGHTS HAVE A LOW AND HIGH BEAM? #11
MF electrical system shows green wire is high beam and tan is low and a ground wire to inside of case. That's the way mine is with the weird lighting for the gauges.
   / MF 135 DO THE HEADLIGHTS HAVE A LOW AND HIGH BEAM? #12
Murph, Jingle. If you send me your email in a PM I'll send you some pages that shows wiring of the switch and wiring colors, so forth. TBN will not allow PDF file attachments. This is from the AGCO service manual. -robert
   / MF 135 DO THE HEADLIGHTS HAVE A LOW AND HIGH BEAM? #13
Kid, I have a OP manual that's how I knew about the color of the wires. Jingle should buy one as the cost is only 12 bucks.
   / MF 135 DO THE HEADLIGHTS HAVE A LOW AND HIGH BEAM? #14
Export or British models may have had a high low beam since they are designed to drive on roads. US production as far as I know there was only a single position light switch on the 135. On mine that is. The manual and parts book backs that up.
British or export models also had more lighting, reflectors and equipped with a hand brake. They had cabs that where optioned. Your tractor light switch would have to have around five or six terminals on the rear to accommodate high low beam. Unless your planning to use it on open roads then IMHO it's a mute point.
My 67 Deluxe has high/low beam. BobG in VA
   / MF 135 DO THE HEADLIGHTS HAVE A LOW AND HIGH BEAM? #15
   / MF 135 DO THE HEADLIGHTS HAVE A LOW AND HIGH BEAM? #16
Bob, do you have those blue lights on your gauges? I too have a 67 deluxe.
Don't really know...never ran it in the dark...actually never have needed the headlights either..BobG in VA
   / MF 135 DO THE HEADLIGHTS HAVE A LOW AND HIGH BEAM? #17
Then how do you know if you have a high and low? :laughing:
   / MF 135 DO THE HEADLIGHTS HAVE A LOW AND HIGH BEAM? #18
OK mr wise guy....you CAN turn on the lights during the day....I just said that I didn't NEED them....BobG in VA
   / MF 135 DO THE HEADLIGHTS HAVE A LOW AND HIGH BEAM? #19
2025 SDLANCH IRGC40 UNUSED Electric Tricycle (A53117)
2025 SDLANCH...
2016 HINO 268 26FT BOX TRUCK (A52141)
2016 HINO 268 26FT...
2016 Dodge Charger Sedan (A51694)
2016 Dodge Charger...
2006 iDrive TDS-2010H ProJack M2 Electric Trailer Dolly (A51692)
2006 iDrive...
2015 Chevrolet Silverado 1500 Crew Cab Pickup Truck (A51692)
2015 Chevrolet...
2010 Ford Crown Victoria Sedan (A51694)
2010 Ford Crown...
