Traveller/TSC oil
   / Traveller/TSC oil #31
warren unilube lists warren oil as it's parent co, and links to warren oil's website.. where you see warren oil and warren unilube listed on the same page. I agree the other one is a different co.
soundguy
Yes, warren unilube. They're in NC
There is Warren Oil in Omaha, as discussed.
There is another company called Warren Oil / Warren Products. They're out of Chicago.
   / Traveller/TSC oil #34
All the talk about oils meeting specs...
I have a question to anyone on here...
Out of all of the oils produced, marketed, re-branded, re-labeled, ect...
Has anyone on here ever had an oil related failure to an engine, transmission, hydraulic pump, ect... that was directly due to the oil not doing it's job of lubrication?
   / Traveller/TSC oil
I know their lawn mower oil excedes B&S's classification requirements. They say SJ or higher. Traveller is SM.
   / Traveller/TSC oil #36
My first skid loader (bought used, 370 hours on it) had it's hydraulic pump fail at 600 hours. Direct result of improper oil, it already did the damage even though I put good oil in it after I got it.
   / Traveller/TSC oil #38
Do you you think the cause was low quality oil, or use of a completely wrong type of oil?
A little of both. I believed they had in it a bad AW68, which was just too thick for the system, combined that with a low quality of oil and the pump went out. It was when I was helping to build my parent's house. We put it in it AW46, a thinner oil, from Conoco. The hydraulics were weak, but it worked. However, that winter the pump just went out. Which, there is no way a pump should go out after 590/600 hours..
   / Traveller/TSC oil #39
strange how we almost never hear about a lube failuer when the correct rated oil is used.. no matter brand
2000 Kenworth W900 - 3406E CAT Engine - 78,980 Miles (A55301)
2000 Kenworth W900...
2015 Ford F-250 Ext. Cab 4x4 Flatbed Truck (A53422)
2015 Ford F-250...
Electric Mobility Scooter (A51694)
Electric Mobility...
2012 CHANDLER 130 BBL STEEL VACUUM TRAILER (A53843)
2012 CHANDLER 130...
2017 Mack GU713 Granite Tri-Axle Dump Truck (A51692)
2017 Mack GU713...
