looking for 101 off the wall uses for my kubota
   / looking for 101 off the wall uses for my kubota #71
Chicken Coop?
   / looking for 101 off the wall uses for my kubota #72
Wildlife transport.
   / looking for 101 off the wall uses for my kubota #73
CBW1999 said:
Anyone can use the bucket as a cooler but, you need something to go along with those frosty beverages.....
<img src="http://www.tractorbynet.com/forums/attachment.php?attachmentid=290821"/>
<img src="http://www.tractorbynet.com/forums/attachment.php?attachmentid=290822"/>
:drink: :cool2:
I do like your style...
   / looking for 101 off the wall uses for my kubota #74
I have a 12 year old still working hot tub that has reached, ( I am told ), It's life expectancy. I can't trust it to make all the way through the winter without breaking down, and freezing, so I put it away in my heated shop.
I made a jig out of channel that my forks pocket into and slide it under.
I have done this for two seasons now and it works great.
   / looking for 101 off the wall uses for my kubota #75
Changing that fuel pump in my truck just got a lot simpler thanks to the kubota.:thumbsup:photo (2).JPGtruckbed.jpg
   / looking for 101 off the wall uses for my kubota #76
Installing that white oak beam for my tractor shed wasn't so bad with the B3200, had to put some blocks under the front tires cause it was not quite tall enough but it worked out great.i3gPictures 276.jpg
   / looking for 101 off the wall uses for my kubota #77
Installing that white oak beam for my tractor shed wasn't so bad with the B3200, had to put some blocks under the front tires cause it was not quite tall enough but it worked out great.View attachment 292061
How did you get the beam up there to start with? balance it on top of the scoop while lifting it and driving it up on blocks?
   / looking for 101 off the wall uses for my kubota #78
I had it clamped down to the bucket with bar clamps, it layed perfectly flat on top of the bucket..
   / looking for 101 off the wall uses for my kubota #79
wildcatblue said:
Changing that fuel pump in my truck just got a lot simpler thats to the kubota.:thumbsup:<img src="http://www.tractorbynet.com/forums/attachment.php?attachmentid=292060"/>
Wow, where is the fuel pump on that Chevy that taking the box off is easier than <whatever> ?
   / looking for 101 off the wall uses for my kubota #80
Fuel pump is on top of the fuel tank and inside most are like that now, removing 30 gal tank on the ground is a real pain with no lift, 8 bed bolts & 3 screws that hold the fuel filler, disconnect wiring harness at the back with just 2 connectors to the bed and she's off total 15 min. I used 4 straps to lift it up with the Kubota and bam everything is easy to get to now.
2018 INTERNATIONAL 4300 26FT NON CDL BOX TRUCK (A52576)
2018 INTERNATIONAL...
Unused 2025 CFG MX15RX Mini Excavator (A50322)
Unused 2025 CFG...
2013 MACK ELITE LEU613 GARBAGE TRUCK (A51406)
2013 MACK ELITE...
Kubota 24in Quick Attach Compact Excavator Tooth Bucket ONE PER LOT (A52748)
Kubota 24in Quick...
12in Digging Tooth Bucket Excavator Attachment (A50322)
12in Digging Tooth...
1996 Carolina Skiff 19ft Fishing Boat with Boat Trailer (A50324)
1996 Carolina...
