Gas Generator to House AC connection???
   / Gas Generator to House AC connection??? #91
Why don't you just install an interlock kit and a terminal box/block to connect your generator. This way you have to turn off the main breaker when you use the generator. It would be a whole bunch safer.
Generator InterLock Kit
Watch the video
Generator InterLock Kit - Introduction
This is the GE interlock kit
Generator Interlock Kit - Product Information
Panel Interlock Kit installation and information (this is a good read)
Panel Interlock Kit Kits - for safely connecting generator power without a transfer switch
   / Gas Generator to House AC connection??? #92
Watch the video
Now this is really genius. In fact I think I'll get going on this suggestion.
   / Gas Generator to House AC connection??? #93
Yes those are ingenius and cost effective. However I dont have a dedicated main line like shown in those illustrations.
just breakers labled AC, Range, Well,one that feed thesub pannel inside it is 60amp, Ect. I dont have 100 amp breaker to disconect from the main pannel to my meter.
   / Gas Generator to House AC connection??? #94
You have 2 options:
1. Replace the panel with a new one that has a main breaker and install an interlock - cost $200ish in parts - Panel: PowerMark Gold 150 Amp 32-Space 32-Circuit Main Breaker Load Center Contractor Kit-TM3215RCU1K at The Home Depot, Interlock: PowerMark Gold Load Center/Generator Interlock Kit-THQLLX1 at The Home Depot
2. Install a transfer switch between the meter and the box, being as you have a 100 amp service, this is probably the cheaper option - $120ish for one of these: 100 Amp 240-Volt Non-Fused Emergency Power Transfer Switch-TC10323R at The Home Depot
Aaron Z
   / Gas Generator to House AC connection??? #95
Not the most inexpensive product to buy, but it fits onto your power meter and offers a whole home transfer switch. GenerLink.com - About GenerLink - The easy way to connect a home generator
No re-wiring or sub panel needed. When the power goes out, hook up your gennie to the connection and use whatever circuits you like in your home providing you stay below the gennie's capacity. I think the line/switch limit is somewhere around 8K continuous watts.
We installed one about 18 months ago. Of course we've only been out of power once for about 4 hours since then!!
   / Gas Generator to House AC connection??? #96
I like that transfer switch offered by the HD. good price seems sturdy and would be my easiest way to hook up a pto gen. safely to the house.
   / Gas Generator to House AC connection??? #98
In case your comment is a partial question, the answer is Yes, this is the easiest and safest way to connect a generator including a PTO generator. You won't be disappointed only wonder why you didn't do it sooner. Good luck.
   / Gas Generator to House AC connection??? #99
How do you shut off all power during an emergency..??
I would have to go out side and turn off each indiviual breaker to the house appliance like well or ac for instance. Im not crazy about the setup Im just trying to figure out how to make it safer.
2013 Ford F-150 4x4 Ext. Cab Pickup Truck (A48081)
2013 Ford F-150...
2015 CAT 573c Fellerbuncher Cutter (A48836)
2015 CAT 573c...
Informational Lot - Financing (A51039)
Informational Lot...
GENERATOR HOUSE POWERED BY TWIN (60 SERIES)  DETROIT 14.0L ENGINES (A50854)
GENERATOR HOUSE...
2015 Freightliner Ambulance (A50323)
2015 Freightliner...
2022 John Deere S780 Combine (A50657)
2022 John Deere...
