PTO shaft with shear pins for snowblowers....
   / PTO shaft with shear pins for snowblowers.... #11
but would replacing the shear bolt PTO with one with a clutch be a good idea?
The problem with running a clutch is snow turns to water on the clutch. Your clutch could be dry, wet, rusting, or froze solid with ice.
I made my own for both Meteors that I have owned. Get a set of Fisher plow shoes, some 2" square tube, and go from there. Here's the two I made, I refined the mounting method on the red one, used a hitch pin instead of the round washers normally found on Fishers.
I'm running a rear mounted Pronovost Puma 54" off my B26 and I'm looking for advice on the PTO shaft. I have 100' of gravel driveway and I regularly break the shear bolts, especially at the start of the season when the gravel is exposed. Now, I'd rather break a shear bolt than a gearbox but would replacing the shear bolt PTO with one with a clutch be a good idea?
MK Martin said no, too many chances that it will not slip.
To follow up, I wound up getting a T50 shaft with M10 shear bolt. Should hold up to the tractor, as the other shaft I had only had an M6....broke that starting the blower with no snow!
   / PTO shaft with shear pins for snowblowers.... #14
To my understanding, clutch pto shafts are mostly for things like rototillers, bush hogs etc -- things that take a constant beating. With a snow blower you shouldn't be breaking shear pins that often.
As someone already said, too much issue with water/ice/rust etc on a clutch shaft on a snow blower. In fact, I've never seen a snow blower with a clutch shaft and I couldn't even count how many different models/manufacturers that has been
Also, for those that aren't aware, shear bolts are a special kind of metal that breaks clean without the bolt stretching. If you use a standard bolt (grade 3/5/8 are the common) they will stretch first before they break making them a pita to change and you risk damaging the shaft
That may be true for some small snowblowers, but all shear pins used on the two Meteors I have owned are normal grade 2/5/8 bolts. Even my Ford brush hog uses grade 2 1/2" bolts for the shear pin. That is straight from the manual in both cases.
   / PTO shaft with shear pins for snowblowers.... #16
Whether you have an HST or a standard shift tractor, lowest RPM's when engaging pto. Also blower should be free of snow before engaging. Some are a little sensitive when engaging. Also, I break 2 or 3 a season.
   / PTO shaft with shear pins for snowblowers.... #17
I've broken one on the pto and one on the auger so far this season. For the pto I use 5/16 bolts 2.5" long with a nut. I get 'em from the hardware store, so they are probably grade 5.
2005 PETERBILT 357 TRI AXLE DUMP TRUCK (A52576)
2005 PETERBILT 357...
2018 RoGator 1100C (A52748)
2018 RoGator 1100C...
2000 TRAILKING TK110HDG-513 LOWBOY TRAILER (A50459)
2000 TRAILKING...
JOHN DEERE ROW MARKERS - SET OF STACK FOLD 12 ROW 30 INCH ROW MARKERS (A52748)
JOHN DEERE ROW...
NEW Wolverine Skid Steer Bucket Root Rake Attachment 34'' (A53002)
NEW Wolverine Skid...
NEW Wolverine 72'' Skid Steer Tiller (A53002)
NEW Wolverine 72''...
