simplicity 26hp 50in cut with full suspension???
   / simplicity 26hp 50in cut with full suspension??? #1
namesray
nc PA.
kubota rtv900: kubota mx5200
might have found my next zero turn. just seen a simplicity zt, 50in deck, 26 hp, and with a spring suspension. i am a kubota guy by experience and not too well sold on simplicity, but this mower ran smooth and actually kinda impressed me. it is a 2009 model so it is used, but from what i saw looked to be in good shape. the blades were in good shape, which i would think be a good indicator of how rough it was used. also it seemed pretty clean. it started good, worked good, and felt good. never operated one with a spring suspension, but kinda liked it. seems like it took a lot of the jar from bumps off the mower and my body. better for both of us in the long run. dealer said new back in 2009 it went for $4600. used, as is to me $2385 out the door. after pricing zero turns and their options, i am almost set on this one. good condition, good cut at 50", and i like the briggs and stratton engines. has the twin hydros trans, and oil filters (hyd and engine) both a plus. only flaws are the hour meter not working and the deck is just a little off level. but that is another thing that impressed me about this mower is how simple everything looks to be worked on and adjusted. just a turnbuckle and lock nuts. everything else is simular adjs. anyone out there with experience with these mowers have an opinion on this one. i think it is a good buy for me. will be used semi commercially to compliment other larger mower with trim work and smalller lawns and as a back up.
   / simplicity 26hp 50in cut with full suspension??? #2
Almost sounds like the champion model. Do you know for sure which model?
Cuts nice...I have one. Also have a citation model. It sound pretty good for use as you outlined. Price sounds good...too bad you don't know hours but if it was maintained even a little sounds like a good price otd.
   / simplicity 26hp 50in cut with full suspension??? #3
It is a Champion.We have sold them for years. Basicaly the same machine as a Ferris IS500 (minus the ROPS and Welded deck)
Good machine if you don't mind the stamped deck.
   / simplicity 26hp 50in cut with full suspension??? #4
:welcome:
STOP!!!! PLEASE READ ALL TERMS BEFORE BIDDING!!! UPDATED TERMS!! (A50775)
STOP!!!! PLEASE...
2016 Freightliner M2 106 Ambulance (A53422)
2016 Freightliner...
2025 12V Diesel Pump and Hose (A50324)
2025 12V Diesel...
2017 FREIGHTLINER CORONADO SD122 DAY CAB (A54313)
2017 FREIGHTLINER...
2014 Dynapac CC4200 Tandem Vibratory Roller (A52748)
2014 Dynapac...
