Corrosion in Electric Panel ... What to Do?
   / Corrosion in Electric Panel ... What to Do?
He can only do that IF he has or can run a 4th conductor between the two panels. It may not be possible/feasible.
Upon closer inspection, the sub panel does in fact have the 4th conductor run from the main.
   / Corrosion in Electric Panel ... What to Do? #22
That's good news GP.
   / Corrosion in Electric Panel ... What to Do? #23
if you have 4 feeders from main, it should be a piece of cake to replace. one suggestion, get a weatherproof NEMA 3R rated panel. these are designed for outdoor use. also, as stated before, dont attach directly to the wall. install a spacer. I generally install deep unistrut to the concrete wall, then install the panel to the unistrut with 1/4" bolts and unistrut spring nuts (they lock themselves into the unistrut).
Silicone the heads of all attachment screws/bolts that you use. get a larger panel ... like either a 30/40 space or a full 40 space to eliminate the doubled up circuits.
good luck
   / Corrosion in Electric Panel ... What to Do? #24
A question to the forum ... Since this is now a sub-panel. Should the neutrals be separated from grounds ? I noticed the panel grounding lug is connected to the neutral...
I was wondering the same thing.
Just to let you all know, I took your advice and replaced the panel and breakers. I also floated the neutral, and eliminated the 1/2 space cheaters, and all breakers have only one wire. The local inspector approved it this morning.
Thanks for your support and advice.
GP.
   / Corrosion in Electric Panel ... What to Do? #26
GP.
Good deal, now you can sleep better without worry.:thumbsup:
   / Corrosion in Electric Panel ... What to Do? #27
per code the sub panel should also have its own dedicated path to ground. eg its own ground rod.
   / Corrosion in Electric Panel ... What to Do? #28
Good to hear you replaced it. I agree it didn't look very good. Not something I'd be willing to live with.
Chad
Hmm. I pointed out to the inspector that, in this subpanel in the house, I did not ground the neutral and kept the grounds separate from the neutral. The main panel has two ground rods and the ground is run to this subpanel ( 4 wires to subpanel, two hots, one neutral and one ground). He said that is the correct way to run it.
I admit, I'm not an electrician and am no expert on code, but this is the way he said to wire it.
He also said that when I run to another subpanel to the barn, to bring 4 wires to the barn sub, float the neutral and that I won't need to keep the ground rod there that I recently put in.
   / Corrosion in Electric Panel ... What to Do? #30
This is the case with a feeder to a subpanel in a detached structure, such as a detached garage.
When the sub panel is in the same structure and is wired with a 4 wire feeder (L1/L2/N/Gnd), the sub panel does not require a supplementary ground rod.
Wrooster
22ft Rolloff Flatbed Body (A51691)
22ft Rolloff...
2014 Ford F-250 Ext. Cab Pickup Truck with Liftgate (A55852)
2014 Ford F-250...
2008 Featherlite Trailer with generator , VIN # 4FGE853218C108480 generator VIN- 4TCSU18516H185904 (A55788)
2008 Featherlite...
2015 Ford F-150 Pickup Truck, VIN # 1FTEW1EFXFFA41510 (A54865)
2015 Ford F-150...
2008 JLG 2630ES ELECTRIC SCISSOR LIFT (A52705)
2008 JLG 2630ES...
UNUSED JCT 2 PRONG BALE SPEAR (A54757)
UNUSED JCT 2 PRONG...
